9706 replies to this topic
#7981 TheFabMini
TheFabMini
  • 459 posts
Posted 28 April 2019 - 06:49 PM
Oil & filter
Flushed coolant
Replace brake fluid
Refitted trim
Checked valve clearance
Greased all the points
Refitted washer bottle
MOT tomorrow ?
#7982 johnR
johnR
  • 2,295 posts
Posted 28 April 2019 - 07:29 PM
Re-connected positive lead from battery ready for first proper run of new engine this week, bent up pipe from fuel pump to carbs - I re-purposed the old one from the 998 but at some point I'll re-make it with new pipe now I've got a template. Checked fuel and water pipe clamps and fitted thermostat cover. Sprayed brake servo. Sprayed second head steady bracket but every time I rub it back the next coat reacts with the previous one so I'll leave it off for now and have it powdercoated.
#7983 Bike1769
Bike1769
  • 46 posts
Posted 28 April 2019 - 08:33 PM
Went for a drive. Throttle stuck on at about 4000rpm.? Something to potter on with during the week.
#7984 Bike1769
Bike1769
  • 46 posts
Posted 28 April 2019 - 08:34 PM
Edited by Bike1769, 28 April 2019 - 08:38 PM.
#7985 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 29 April 2019 - 06:02 AM
Cut and fitted N/S Polycarb windows, fitting O/S windows today. Hopefully cutting the rear window today too.
Filled and welded up the aerial hole in the wing (the aerial on mine is in the roof)
Might have a tidy inside for peace of mind.
#7986 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 29 April 2019 - 08:13 AM
Finally found a set of 5 nice aluminium wheels to replace my standard 3,5" steelies.
They are the 4-spoke wheels from the Leyland Trophy in France back in the mid to end of the 70's.
I think they will help cooling down the Cooper S front brake!
Can't wait to have them home!!
#7987 minifreek1
minifreek1
  • 1,260 posts
Posted 29 April 2019 - 09:17 PM
Started to modify the top dash pad to accept triple guage and tweeters.
#7988 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,024 posts
Posted 03 May 2019 - 06:48 PM
Washed it and joined the convoy to Pentewan sands for Cornish mini clubs riviera run this weekend. https://cmcrivierarun.co.uk
#7989 Bike1769
Bike1769
  • 46 posts
Posted 04 May 2019 - 11:22 AM
That's a lovely looking car. Enjoy the weekend.
#7990 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 10 May 2019 - 03:37 PM
Given it a good check over and polish/wax for the London to Brighton next week. Hopefully the weather will be good again ☺️
#7991 RichMPiBlue
RichMPiBlue
  • 441 posts
Posted 10 May 2019 - 06:36 PM
New c/v gator kit fitted, front inner wheel arch and rear inner wheel arch welded/sealed. ✅
New Yokohama A539 tyre fitted and balanced. ✅
MOT passed. ✅
All ready for Himely Hall Mini show this weekend and L2B next weekend. ✅
6-D9934-FF-1-E77-4-C9-A-B075-FC693-D6135
#7992 minifreek1
minifreek1
  • 1,260 posts
Posted 12 May 2019 - 08:17 PM
Removed front windscreen.
Removed scuttle panel.
Removed both front wings and front panel, ready for when I can buy and fit a flip front. Scuttle was only supposed to be a repair but is too far gone and needs replacing.
#7993 MuppetDonkey
MuppetDonkey
  • 53 posts
Posted 20 May 2019 - 09:21 AM
Finally took my little girl to school in it :)   She giggled all the way!
#7994 guywilko
guywilko
  • 46 posts
Posted 20 May 2019 - 10:35 AM
Torqued up maltese crosses
Checked front suspension torque.
Found a carb rubber grommet sat on the gearbox linkage, replaced it under the twin carb airbox!
Checked front headlight connectors.
Set plug gaps.
Played around with CSI dizzy curves.
Fitted rivnuts to grille mounting points, titanium bolts to replace self tappers.
Talked myself into buying KAD rear subbie geometry plates.
MOT no advisories!!! YAYYYYYY!!!!!
#7995 minifreek1
minifreek1
  • 1,260 posts
Posted 20 May 2019 - 07:04 PM
Replaced NS doorstep, decided to buy a half floor because it got too many patches now. Payday Thursday so we'll see what the bank sez I can buy this month..
8 user(s) are reading this topic
3 members, 4 guests, 0 anonymous users
    Bing (1), Matt 81, GT Jimmy, RichMPiBlue
