9722 replies to this topic
#7681 Kombi
Kombi
  • 105 posts
Posted 09 September 2018 - 03:58 PM
Installed new fuel pump, pre-filter, and new rubber lines in the rear and up front.
The best part, I appear to have solved my stalling/completely-not-running problem.
#7682 DeanP
DeanP
  • 499 posts
Posted 09 September 2018 - 04:04 PM
Car returned from "Old Skool Mini's" and so the assembly begins.
https://photos.app.g...sRUSzHFpKVjNef9
Hopefully the link works......
#7683 RooBoonix
RooBoonix
  • 1,224 posts
Posted 09 September 2018 - 04:26 PM
It works :)
#7684 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 September 2018 - 10:34 AM
All teething issues sorted, idles smooth and revs free.
https://youtu.be/q8RTXzILtAQ
#7685 Cooperman
  • 23,276 posts
Posted 21 September 2018 - 03:45 PM
Re-fitted the big sump guard on the 'S' rally car, Waxoyled the repaired A-panel, inside the sills and under the front wings, removed and re-greased the rear sub-frame trunnion bolts.
#7686 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 21 September 2018 - 04:27 PM
Cut it to bits, a bit worse than anticipated
#7687 sc-em
sc-em
  • 181 posts
Posted 22 September 2018 - 07:01 PM
Chipped the bloody sound deadening off the floors so I can see the good metal. What a pain of a job.
#7688 Chris.Williams
Chris.Williams
  • 679 posts
Posted 22 September 2018 - 10:40 PM
Put the rear window in, gave it a once over then hit the road.
Just a test squirt as it’s still not fully tuned.
OH MY DEAR GOD - - Caution, May cause involuntary bowel evacuation!
So good, I have no real way to describe it, well not with words I can use on here haha
Edited by Chris.Williams, 23 September 2018 - 12:50 AM.
#7689 Chris.Williams
Chris.Williams
  • 679 posts
Posted 26 September 2018 - 09:11 AM
Fitted a DSN steering column drop. Not the easiest of jobs, but worth the effort.
#7690 SuperDeLuxeNick
SuperDeLuxeNick
  • 615 posts
  • Local Club: West Country Minis
Posted 26 September 2018 - 11:18 AM
3 days worth here - refurbed the seat brackets and sprayed them, fitted extenders at the same time, located an oil leak and fitted HI-LOs all round. lovely.
#7691 Hamstein
Hamstein
  • Just Joined
  • 107 posts
Posted 26 September 2018 - 05:27 PM
Finally my mini has it's floor in, just a few more welds to clean up....... and then pretty much every other panel on the car to replace! O_O
#7692 Big Sam
Big Sam
  • 853 posts
Posted 26 September 2018 - 06:59 PM
Front subframe is now completely detached ready to be removed.
Went about getting doors off as they are the last things to remove before I can crack on with a full resto. Bolts were a pia. Started removing a panel as it's getting replaced only for grinder to pop.
Went to Screwfix to talk about replacement, under two years but their pcs only go back 18 months so need to wait for head office to authorise the replacement.
While I was there bought the Erbauer bolt extractor kit as I can't keep attacking things with a grinder. It's a brilliant piece of kit and removed the tricky one at the top with ease even after the attacks with the grinder. Have full confidence it could do any bolt. Highly recommend everyone has one in their toolkit.
#7693 Chris.Williams
Chris.Williams
  • 679 posts
Posted 27 September 2018 - 03:17 AM
Dyno session booked for 12th of October.....can’t wait
#7694 Gcal
Gcal
  • 128 posts
Posted 27 September 2018 - 07:27 PM
Found a small oil pool on the garage floor at the front of the mini on closer inspection it was a loose oil filter so I have tightened it back up
#7695 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 29 September 2018 - 01:07 PM
Gave away a flat roof '64 Countryman that is in the way in my workshop.
Watch this space...
    Bing (1)
