#7621
Posted 10 August 2018 - 05:17 PM
The radiator has a hairline crack where the bottom hose takeoff is welded on
#7622
Posted 10 August 2018 - 07:44 PM
#7624
Posted 11 August 2018 - 04:39 PM
Not on the mini, but for the mini.
Finally got round to buying some co2/argon mix and a welder to practice with.
Turns out if you actually open the regulator the welds look so much better! Who knew?
#7625
Posted 11 August 2018 - 06:33 PM
Change the master cylinder too, had this on our 88 998 MayfairTook delivery of a new brake servo. Had a bit of a nasty experience the other night on the way home from a pub meal when the brakes went a bit strange. Checked the fluid level the next morning and it was empty
Went round all the cylinders and pipes with no sign of a leak - pulled the vac pipe off the manifold and brake fluid dripped out, probably the cause of the slight burny exhaust smell I get with the windows open. New servo to be fitted tomorrow.
Dohhhhh, what an idiot I am What you said is of course true - where else would the fluid come from except the master cylinder, I was thinking remote servos not the type fitted to late Minis like mine
Took the old servo off
A bit damp in there
This is about half of what came out
The master cylinder is weeping ever so slightly at the back seal but I'll need to move the car around tomorrow and will order a new master next week
OOOOO shiny
Isn't the bottom fixing nut interesting to get back on
Edited by panky, 11 August 2018 - 06:59 PM.
#7626
Posted 11 August 2018 - 06:34 PM
Fitted new door seals and also fitted seat extenders, next job is to establish why the seat locking doesn't work
#7627
Posted 11 August 2018 - 06:48 PM
With the seat position extenders the locking latch on the seat can be too far back to engage on the bar on the floor. I have to push the seat forward to engage the locking mechanism then push it back to it full travel, trouble is if you tilt the seat forward the latch misses the bar again when you drop the seat.
#7628
Posted 11 August 2018 - 07:15 PM
Many Thanks for the advice I will give it a try
#7629
Posted 11 August 2018 - 07:39 PM
Mine went the same way (almost hit my mum's car as I was pulling up behind it)Change the master cylinder too, had this on our 88 998 MayfairTook delivery of a new brake servo. Had a bit of a nasty experience the other night on the way home from a pub meal when the brakes went a bit strange. Checked the fluid level the next morning and it was empty
I also found that bolt a pain in the a**xD
Edited by bae1994, 11 August 2018 - 07:40 PM.
#7630
Posted 11 August 2018 - 08:47 PM
Today I made this, A piece of foam cut to suit my spare wheel that holds a (cut down to fit) breaker bar, a socket to fit the alloy wheel nuts, a socket to fit the steel wheel nuts, locking wheel nut socket, and 4 steel wheel nuts. Just need to paint the wheel now.
and doesn't fall out when upside down
#7631
Posted 13 August 2018 - 03:36 PM
#7632
Posted 13 August 2018 - 07:00 PM
We had an issue where the car would drain the reservoir but if I filled it back up the pedal is still perfect, the servo was dry the cap was changed a few times.Dohhhhh, what an idiot I am
A bit damp in there
OOOOO shiny
We never did find the issue but replaced the master cylinder with a new one and it's been perfect since ?
Edited by cal844, 13 August 2018 - 07:02 PM.
#7633
Posted 14 August 2018 - 11:53 AM
Think I’ve found myself a Mini friendly tester!
#7634
Posted 14 August 2018 - 03:37 PM
Put it back on trickle charge in the garage after leaving it off a few days (as they recommend you don't keep them on 24/7 lol). Doing a run to the Cotswolds in it on the 24th-25th---looking forward to taking it out!
#7635
Posted 17 August 2018 - 07:28 AM
