9707 replies to this topic
#7501 Readers14
Readers14
  • 439 posts
Posted 26 June 2018 - 09:07 PM
Gave it a quick detail whilst I was in the garage.
#7502 ClassicAsh
ClassicAsh
  • 139 posts
Posted 27 June 2018 - 11:17 AM
I had noticed that there where a few rattles, creaks and bangs of late through the suspension and the steering wheel, had been putting off looking for a few months but it was getting worse. so today this morning decided to take a look. on the front the steering rack mounting bolts where not as tight as I remember so gave them a few turns. test drive and that was the clunky steering sorted. now the back. after much consideration I decided it must be the shock absorbers moving and transferring the clunk through the rear suspension, so moved the petrol tank to one side and gave the mounting bolts a few turns and locked with the lock nut, and the same with the other side. test drive and that sorted. Its probably phycological but the car feels much better and a hell of a lot quieter over the bumps now. A productive few hours in the garage for a change !
#7503 minitravellerman
minitravellerman
  • 99 posts
  • Local Club: Minis In Northern Ireland
Posted 28 June 2018 - 09:25 AM
Swapped over a few parts on my rally Mini to put it back to standard for selling
#7504 musicmanno1
musicmanno1
  • 132 posts
Posted 29 June 2018 - 09:00 PM
Took the mini out for a fresh polish and a short run after only doing 16 miles last year-kids eh!!
#7505 Mito
Mito
  • 414 posts
Posted 30 June 2018 - 01:26 PM
Carried on some welding on the rear corner.
Attached File  1530365015989131946111.jpg   67.87K   1 downloads
And then started grinding back...
Attached File  1530365089603-753190766.jpg   92.2K   2 downloads
Oops!
#7506 Hamstein
Hamstein
  • Just Joined
  • 107 posts
Posted 30 June 2018 - 06:09 PM
Removed all the bitumen sound deadening, and with the help of a mate and a bit of swearing, got it up on the roller jig.
#7507 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 30 June 2018 - 07:49 PM
Started making preparations for fitting new exhaust.
Carb off manifold nuts off, servo pipe disconnected
Manifold off. Will also be renewing the fuel lines and putting a new fuel pump on whilst everything is out of the way.
Other jobs were oil change, filter change, coolant dropped and flushed new temp switch in rad as old one is knackered. Still plenty left to.
#7508 poohbah
poohbah
  • 55 posts
Posted 02 July 2018 - 01:49 PM
Drove it around London in the sweltering heat, and was relieved that I had an electric fan fitted in addition to the belt-driven one.
#7509 vyruskiller
vyruskiller
  • 79 posts
Posted 02 July 2018 - 06:36 PM
Took Percy the GT for his MOT....passed with flying colours - phew!
#7510 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 03 July 2018 - 06:35 AM
What's the steel pipe coming off the down pipe?
#7511 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 03 July 2018 - 07:31 AM
I have a 1993 carb so this is a gas analyzer pipe. Was fitted as standard from the factory for the CO readings when setting mixture etc.
#7512 Hamstein
Hamstein
  • Just Joined
  • 107 posts
Posted 03 July 2018 - 05:06 PM
Drilled out more spot welds than i cared to count, removed r/h companion bin.
#7513 Dannyboolahlah
Dannyboolahlah
  • 168 posts
Posted 03 July 2018 - 05:32 PM
Drove it 2.5 hours half way across the country, smashed it round Blyton Park for a bit then drove it home.
All went pretty well apart from some of the oil falling out! Haha
#7514 Readers14
Readers14
  • 439 posts
Posted 03 July 2018 - 06:12 PM
Whilst I had the rear shock off, I decided to hammerite the drum & radius arm.
Looks pretty nice now!
#7515 Wiggy
Wiggy
  • 1,036 posts
Posted 03 July 2018 - 09:14 PM
Took Mini for an MOT for the first time in 10 years.
Failed. But only on rear brake imbalance and a split steering rack gaiter. So I can't really complain!
The tester was very complimentary too. Liked the fact I'd treated the beginnings of rust and had greased all the nipples. He said she was clearly cared for.
Edited by Wiggy, 03 July 2018 - 09:15 PM.
    Bing (1)
