9712 replies to this topic
#7366 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 12 May 2018 - 05:38 PM
Attended the Amberley Mini day, they were expecting 100 Mini's but I think only half that total attended, here's a few photos I took.
https://imgur.com/tPILv4B
https://imgur.com/HWHP3nB
https://imgur.com/R0HXC6s
https://imgur.com/ohHF1nS
https://imgur.com/67XwXtG
https://imgur.com/hBEIsHF
https://imgur.com/WcXReKO
https://imgur.com/nw4z6n5
https://imgur.com/l9bczrx
https://imgur.com/YQdQWLw
You seem to have uploaded them incorrectly, did you upload them on a pc?
I did upload them on to my PC I will attempt to add the correct link
Edited by JXC Mini GT, 12 May 2018 - 05:38 PM.
#7367 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 May 2018 - 05:41 PM
In future the best way to do it is to select the picture you want and click on it. The list of options will appear on the right side of screen, scroll down to the bottom of the list and click copy and then paste the link into your post.
#7368 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 12 May 2018 - 05:43 PM
2nd attempt of images
#7369 Wiggy
Wiggy
  • 1,036 posts
Posted 12 May 2018 - 10:29 PM
Fixed my hazards and indicators. Flasher unit was sticky from 10 years inactivity.
Fixed 1 indicator that wasn't working. Dirty connection.
Fixed low brake fluid warning light that wasn't working. Had to take the reservoir cap to pieces and clean it up.
Fixed the non working horn. Had to rewire the connectors coming in and out of the Rotary Coupler onto fresh circuits within the Coupler.
I'm happy!
#7370 Syma
Syma
  • 73 posts
Posted 13 May 2018 - 03:05 AM
Spent the day installing my freshly rebuilt overboard 998 and then realizing the distributor gear was in 180 degree out, fixed and fired right up. Sounds great and runs way way way better then before. My old rings had a 1/8" gap when I tested them in the cylinder so that lead to a rebore, new pistons and rings. First test drive was good until my exhaust fell off, oops didn't tighten a clamp or two. Second test drive was really good until it stalled on the side of the road and wouldn't start again. It clicks but will not turn over so I assume battery or some connector. Had it towed home and I will sort it out later
#7371 cal844
cal844
  • 9,621 posts
  • Local Club: TFMOC
Posted 13 May 2018 - 06:27 PM
Yesterday was a nightmare! We have had issues on one car with the speakers randomly cutting out on bumps. So we fixed that issue, however while out on the test drive the drivers(RHS) front knuckle joints sheared at the ball, just below where the rubber boot would sit! Wasn't too bad to fix but still a pain lol
#7372 RichMPiBlue
RichMPiBlue
  • 447 posts
Posted 14 May 2018 - 05:32 PM
A few tidy up bits getting ready for L2B the weekend.
#7373 Wiggy
Wiggy
  • 1,036 posts
Posted 14 May 2018 - 09:51 PM
For the first time in 10 years, I drove my Mini. Mainly due to screwing it up, then having self confidence issues and burying my head in the sand......
But I have fixed her.
Albeit, it was up and down my cul-de-sac.
God damn is feels good to hear that 1st gear whine and bwarp from the exhaust.
Yep. I'm happy!
#7374 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 14 May 2018 - 10:05 PM
Fit the new battery and turned the engine over for the first time - got oil pressure in 5 seconds!
#7375 Chris.Williams
Chris.Williams
  • 679 posts
Posted 15 May 2018 - 10:38 AM
Cleaned up my new head, fitted my gaskets and decompression plate, torqued down the head.
Fitted New engine breathers to the fuel pump hole and the transfer case. Cheers DSN
Offered up the supercharger........dribbled for a bit 😍
#7376 Chris.Williams
Chris.Williams
  • 679 posts
Posted 15 May 2018 - 10:41 AM
Almost forgot, purchased a dowel adjustable beltdrive from eBay.
Just needs a new belt, 52 teeth, 10mm wide I believe.
#7377 paul50
paul50
  • 86 posts
Posted 15 May 2018 - 05:41 PM
Went to regency autos in Cambridge to put Elmo the 998 on the rollers. 61.9 hp and 88.1 nm of touque. Not to bad if I do say so myself. The calver st head has made loads of extra power about 20hp .big thanks to Peter Baldwin and lee
Edited by paul50, 15 May 2018 - 08:02 PM.
#7378 ClassicAsh
ClassicAsh
  • 139 posts
Posted 16 May 2018 - 06:54 AM
Changed the engine oil and filter today, was a cheap job too, I purchased 4 x 4.5 litre comma oil 20/50 for only £34.49 (good old ebay) and got myself some Crosland filter from Car parts for less. at only £1.45 each so I bought 4.  sorted for the next four years, and works out at only £10.07 per oil change. happy days.
#7379 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 16 May 2018 - 08:17 AM
That oil is a bargain - might get some myself. Is the zinc content and everything else all ok for the mini?
#7380 ClassicAsh
ClassicAsh
  • 139 posts
Posted 16 May 2018 - 09:38 AM
I am not sure to be honest, I have used it in every oil change the mini has had, so that's 5 since I have had it. its the Comma Xflow type MOT 20W/50. never had any issues with it, I only do about 500 to 1000 miles a year. and at that price its a bargain.
