9722 replies to this topic
#7246 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 04 March 2018 - 02:06 PM
Fancied having a go at making a flip lid rocker cover.
Attached File  IMG_0396.jpg   114.53K   0 downloads
Attached File  IMG_0397.jpg   125.58K   0 downloads
Attached File  IMG_0398.jpg   105.79K   0 downloads
Attached File  IMG_0399.jpg   109.48K   0 downloads
Attached File  IMG_0400.jpg   122.41K   2 downloads
Attached File  IMG_0438.jpg   62.53K   2 downloads
Attached File  IMG_0472.jpg   114.9K   2 downloads
Attached File  IMG_0473.jpg   114.98K   6 downloads
Attached File  IMG_0472.jpg   114.9K   4 downloads
#7247 MacGyver
MacGyver
  • 1,027 posts
Posted 04 March 2018 - 02:58 PM
I want one!
Does it have a breathing hole or something?
#7248 Mini-dude
Mini-dude
  • 116 posts
Posted 04 March 2018 - 02:59 PM
I like it very nice.
#7249 Raggedroy
Raggedroy
  • 89 posts
  • Local Club: None
Posted 04 March 2018 - 03:07 PM
Does it have a breathing hole or something?[/quote]
I machined out the hinges and put a gauze in them, then drilled a hole through the side of the hinges and also through the lid.
#7250 Kombi
Kombi
  • 105 posts
Posted 05 March 2018 - 04:06 AM
That's a really cool, I wonder if some clear plastic would be strong and heat resistant enough to serve as the cover.
My goal for today was to get the alignment done. I started working on the rear and was adjusting the rear camber plates I have. I was tightening the outside nut on the pivot shaft use the torque specs from the N/M column. The only problem was I was setting the wrench in LBS/FT. Much cursing ensued after the threaded end popped off.
So now I'm ordering another shaft and hoping like heck that I won't have to completely redo the bushings. :angry:
#7251 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 07 March 2018 - 09:15 PM
Checked the cam timing after fitting the cam to in the 1293 build at the weekend,  Kent 266 cam should be 106 degrees ATDC minus around 2 for the chain stretch, I got 104.25 degrees just from fitting the vernier chain and gears as is from the manufacture  :gimme:
#7252 SolarB
SolarB
  • 1,385 posts
Posted 08 March 2018 - 07:57 AM
Waded through the Minispares website and worked out the mild restoration of my car is going to be around £2000 in parts.
#7253 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 08 March 2018 - 11:42 AM
Ha, been there.... and it just keeps growing doesn't it.
#7254 TobyM2018
TobyM2018
  • 100 posts
Posted 08 March 2018 - 02:21 PM
Not very exciting but this novice did his first oil, oil filter, air filter and spark plug inspection on a 95 Spi. Took my time and learnt a few things as I went as we always do... ;)
Noted spark plugs had distinct grey tinge to them and were by unipart rather than the usually suggested NGK. Other than that we seem ok!
Like I said not very exciting but it's an important start
#7255 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 08 March 2018 - 05:44 PM
Broke down again.
#7256 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 08 March 2018 - 08:13 PM
Booked it for its MoT tomorrow at 2....
Had to weld the rear subframe as it simply wasn't attached to the car......... god knows how it hasnt killed me....
Anyhoo, all I have to do is adjust the handbrake and tidy it up and take it to the test centre..... I got me some beer so I can sleep, otherwise I'll not sleep....
#7257 TobyM2018
TobyM2018
  • 100 posts
Posted 08 March 2018 - 08:19 PM
Good luck pal!
As you say luck appears to be on your side at the moment anyway ;)
#7258 panky
panky
  • 1,790 posts
Posted 08 March 2018 - 08:25 PM
The weight of that battery you've been carrying around probably kept the back end in place ;D
#7259 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 08 March 2018 - 11:11 PM
Well done, you should be pleased you've made the attempt. Everyone has to start somewhere.
#7260 Mini Waco
Mini Waco
  • 438 posts
Posted 08 March 2018 - 11:16 PM
Picked up my 64 Cooper barn find. Pulling it home now (wife driving) -9 hours into drive.
