9971 replies to this topic
#7216 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 19 February 2018 - 03:43 PM
Finally got fed up trying to get the roller bearings out of my top arms so I did what I should have done a few months back and just bought brand new top arms, so I've got new donuts, hi-lows and top arms fitted on the passenger side and now waiting for the upper ball joint on the other side to pop off so I can do the other side. Think I did everything properly and hopefully the other side will be done a hell of a lot quicker, only issue is because it's sat all winter it won't start now but I'm hoping it will fire up after I've cleaned the carb out.
#7217 panky
panky
  • 1,850 posts
Posted 19 February 2018 - 04:17 PM
Realised the brake lights weren't working and found one of the connections on the pedal switch was broken off. Must have happened when I was putting the fresh air ducting back on a couple of weeks ago O_O , it's a tight fit in front of the pedal and rests against the connections. Did a temporary fix by soldering a piece of wire onto the broken connection and ordered a new switch, this time I'll put it back with the wires pointing the other way so less chance of it coming in contact with the trunking - hopefully.
#7218 joakwin
joakwin
  • 958 posts
Posted 20 February 2018 - 01:29 AM
40362115991_c6020e49a6.jpgmore brake brackets by joaquinn lopez, on Flickr
39469336955_08f349e273.jpgrear brake bracket left by joaquinn lopez, on Flickr
i cut this bracket out for the left rear and painted it
disc brake caliper mounting bracket for Honda brakes on my mini
#7219 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 20 February 2018 - 09:00 AM
Walked past it, stopped and stared for a while, patted it on its roof..... Sighed.... And went inside to start pricing up panels....
#7220 Steve220
Steve220
  • 5,143 posts
  • Local Club: BMC
Posted 20 February 2018 - 02:09 PM
Sat on the garage floor making brum brum noises whilst hugging the engine..
#7221 ClassicAsh
ClassicAsh
  • 139 posts
Posted 20 February 2018 - 04:33 PM
As its a dryish I decided to take it out of winter hibernation, check all fluid levels etc, started first time, Drove it out the workshop, decided to wash it, then picked my two boys up from school it in, I gave one of their friends a lift too, it was worth it to see all three of them smiling as we dashed along as break neck speed (actually only 25MPH but they thought it was soo cool) and there is the fun in a mini, it might be slow but it always feels fast.. :proud:
#7222 panky
panky
  • 1,850 posts
Posted 20 February 2018 - 05:05 PM
Fitted some switches and relays for fogs and spots and to get rid of a couple of random switches I'd installed over the years. Finished for the day and pushed the garage door shut when there was a almighty bang :o It turns out that a WW2 bomb was found up the road in St Helens and the bomb disposal squad carried out a controlled explosion - nearly crapped meself  :shy:
#7223 panky
panky
  • 1,850 posts
Posted 21 February 2018 - 05:01 PM
Fogs and spots all working. Spots use a signal from high beam through a switch to operate and fogs similarly from the rear fog lamp.
Relays
Switches off
Switches on
Looks like Christmas :proud:
#7224 Eds.mini.lulu
Eds.mini.lulu
  • Just Joined
  • 137 posts
Posted 21 February 2018 - 05:09 PM
replaced clutch slave cylinder...never again..hopefully
#7225 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 February 2018 - 10:22 PM
😮 Must have been loud 😂
#7226 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 February 2018 - 10:25 PM
Today I got the car in my avatar passed its 6th MOT in my ownership 😁
#7227 panky
panky
  • 1,850 posts
Posted 21 February 2018 - 10:31 PM
Must have been loud
It was one of those when you jump up a foot in the air without realising O_O
#7228 Midas Mk1
Midas Mk1
  • 5,852 posts
  • Local Club: S.U.N.M.C
Posted 21 February 2018 - 10:58 PM
Added more stuff to the to do winter list.. Better step up a gear.. 😫
#7229 minifreek1
minifreek1
  • 1,260 posts
Posted 22 February 2018 - 11:15 AM
Decided to replace the N/S A Panel.....
Obviously had to remove the door, it didnt want to be removed and I ended up shearing off the top studs for the hinge.... so now had to repair the door as well as the A Panel... Anyhoo, replaced the A panel and did a small repair to the front of the sill and floor. Drilled out the studs that remained in the hinge and replaced them with bigger bolts, tapped the threads into the hinge and welded the back of the bolts best i could.... really should have covered the window in the door... it now has weld splatter in many places and the window now needs replaceing too.... happy days...
Off to a parents evening thing in the afternoon today then gonna start on the O/S A Panel.... I know exactly what needs doing behind it too.... gonna be a long day today....
#7230 old original
old original
  • 353 posts
Posted 22 February 2018 - 03:48 PM
Left it at home,caught the bus, now on the pop....yay!
11 user(s) are reading this topic
3 members, 8 guests, 0 anonymous users
    colinf1, MiniFanGraham, Midas Mk1
