#7201
Posted 20 January 2018 - 11:40 PM
#7202
Posted 22 January 2018 - 11:57 AM
Got told the job which should have been done on it last week hadn't even been started as they returned the panel due to quality of it... not making it to Bingly this year then
#7203
Posted 26 January 2018 - 05:50 PM
Split the engine to see what was wrong with the gears........
Edited by BronkoMini, 26 January 2018 - 05:51 PM.
#7204
Posted 27 January 2018 - 05:23 PM
#7205
Posted 27 January 2018 - 05:40 PM
I re-fitted the original Cooper air trunking a while ago but it was touching the bonnet strengthening slightly because of this
None standard for the carb Cooper engine, one I put on ages ago when I was running a K&N cone.
Got the proper type and now there's plenty of clearance
Also nicked the rocker cover off the traveller
I had a few annoying rattles and finally traced them - one of the arch extensions had lost a screw and it was buzzing like a demented bee so easy fix. A couple more traced to the doors where I'd forgotten to replace the thin foam rubber washers around the window winders behind the door card and the plastic bezels were rattling away - I found them in a bucket of bolts, re-fitted and now rattle free
Cant drive at the moment though - dodgy knee
Edited by panky, 27 January 2018 - 05:43 PM.
#7206
Posted 30 January 2018 - 07:36 AM
Woke it up from its winter hibernation to circulate the oil, move the brake and clutch hydraulics and turn the tyre contact patch.
It was fast asleep and took a little persuading to come to life
#7208
Posted 30 January 2018 - 04:37 PM
Bagged a dipping rear view mirror off Ebay for 99p and fitted that
Also got a pack of sound deadening, similar to the stuff Ben_O used on the green Cooper, to cover the floor repairs and a few other bits
This is the size of sheet you get - ten of them for under £15 posted
Under the bonnet
It's got a nice weight to it now and closes with a thud rather than a clang
Had enough to do the same to the other front floor pan and the rear passenger side, where I'd chipped the original bitumen stuff off, as well as a couple of sheets for the rear seat back and some offcuts for the boot lid and spare wheel well.
Linky
https://www.ebay.co....872.m2749.l2648
#7209
Posted 01 February 2018 - 06:53 AM
Just a few power runs to give me a benchmark and see how the fueling was looking
Little more needle shaping needed as it leaned out after 5k
Pretty happy with the 76 hp at the wheels
Once Im happy with the fueling Ill take it back and fine tune the advance curve
#7210
Posted 01 February 2018 - 04:11 PM
New plugs, Distributor cap and rotor arm, clutch wasnt working fluid level has dropped, bled clutch filled up with dot 4 working.....for now. . got round to sorting the ball joint dust caps.....what buggers n\s\f done...minus two nuts and washers which i need to order. nuts where either incorrect or threads where knackered, should have been a straightforward job but no....i now have 2 less knuckles and 2 blood blisters
. still need to do o/s/f im expecting the same level of fun!!.....anyone had any troubles with grease guns? managed to get the gun stuck on the greaase nipple and now cant remove it had to unscrew grease nipple to free gun!!
was hoping to have it all done in a couple hours how wrong was i !!
#7211
Posted 02 February 2018 - 11:16 AM
Set about finding out why my Mini has a creaking type noise from front left, only thing I could find was a loose track rod end, so after a fight with the old one which involved a lot of swearing and heat from my 2 blow torches, it decided to relent and let go.... Replaced with a new one, did the Ed China thing of counting how many turn it takes to remove, then the tracking won't be far out.... That didnt work, so have eyeballed the tracking for now, looks OK, but not took it for a drive just yet. Also wound the coils up by 1 turn at the front, looks like its on ruddy stilts now....
#7212
Posted 02 February 2018 - 06:37 PM
#7213
Posted 03 February 2018 - 08:53 PM
Wheeled the shell out of the garage, tidied and swept around it to make space to work, then put it up in the air on saw horses so it's easier to work on.
It's easier to see all the work that needs doing also
#7214
Posted 03 February 2018 - 09:00 PM
Got some filler on the fibreglassing that I done, it's amazing how original you can make it look with fibreglass and expanding foam.. Photos in the last 2 posts in my project thread. http://www.theminifo...rebuild/page-39
Edited by alex-95, 03 February 2018 - 09:02 PM.
#7215
Posted 05 February 2018 - 07:35 PM
After my respray the end of last year, I finally got round to pot riveting my arches back on today and placing the rubber seams on as well.
