9721 replies to this topic
#706 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 19 February 2011 - 08:53 AM
started to sand bog on my inner wings got bord after about 5 seconds
so took the subframe out and cleaned ready for some welding tomorow
#707 Mark_Pieman
Mark_Pieman
  • 63 posts
Posted 19 February 2011 - 03:18 PM
Swapped fuel lines in engine bay for stainless braided ones with nice red finishers :o
Put battery on charge :)
#708 david_vennard
david_vennard
  • 151 posts
  • Local Club: East Coast Minis NI
Posted 19 February 2011 - 04:20 PM
was being nice to the car and washed it, goin 2 go for a drive, but then it just kept turning over, turned it off but still was turning over and i was like O: ive *insert word here*.
was goin threw what it all could be, for a bit i thought it was the ignition barrel, so disconnected the startermotor, turn the key to the II and the radio lights and so on worked. so it wasnt the ignition barrel
so after a bit of hmmming and haaaing, had a look at the startermotor and looked at the solenoid.
so long story short the solenoid was stuck on therefore when the battery was connect it was turning over without the key
on the bright side if i had a new car, you wouldnt have a hope to fix it
went for a drive, drove lovely, didnt miss a beat
#709 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 19 February 2011 - 04:31 PM
thought about selling it
#710 j-b_2009
j-b_2009
  • 164 posts
Posted 19 February 2011 - 04:34 PM
drilled spot welds and my fingers several times.
#711 1984mini25
1984mini25
  • 8,784 posts
Posted 19 February 2011 - 04:37 PM
Played around with the pressure relief valve so I had a more reasonable amount of oil pressure while cranking. It was up near 100psim, but it’s not down to a more reasonable 60psi. So hopefully it won’t be long before I can safely start it for the first time.
I also bleed up my front brakes, as a bonus my £10 second-hand metro 4 pots are fully working. Just need to find a replacement master cylinder so I can have some rear bakes as well now.
#712 bcjames
bcjames
  • 2,728 posts
Posted 19 February 2011 - 04:43 PM
My shim-shim-shim noise coming from the brakes was actually the CV boot clip fouling slightly on the hub's inner. Sorted now, too wet to go for a drive today for the sake of it though :)
#713 new_zealand _minis
new_zealand _minis
  • 654 posts
Posted 20 February 2011 - 12:26 AM
strengthening my subframe same as in jan issue or mini world . looks identical to that one
#714 samsfern
samsfern
  • 5,243 posts
Posted 21 February 2011 - 07:06 PM
finished fixing it, and took it for a drive down some muddy country lanes, got it filthy, drove through a puddle and it cut out, so as i was spraying the wd40 about, i heard a pheasent grunting at me, which then proceeded to attacking my wheels, then chased me around the mini, then chasing and attacking the mini as i drove off, my friend were in stitches laughing :-
#715 MITCH959
MITCH959
    Just On Tickover
  • 8 posts
Posted 21 February 2011 - 07:18 PM
Checked the play in the selector rod and found out my oil seals for the selector right side driveshaft. Washed the underneath of the car and hoovered the inside. Last of all put my new mini sport mats in and put it to bed :-
#716 haggz
haggz
  • 329 posts
Posted 21 February 2011 - 07:40 PM
nothing done on the car but bought some nice new parts
#717 Assassin
Assassin
  • 43 posts
Posted 21 February 2011 - 08:34 PM
Received a few parts today.
Attached File  DSC00521.JPG   5.65MB   9 downloads
#718 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 21 February 2011 - 08:47 PM
started to clean it to try and get selling it out of my mind
#719 Kimberley x
Kimberley x
  • 255 posts
  • Local Club: Small 'n' Mighty Minis
Posted 21 February 2011 - 09:28 PM
Shouted at it alot for being pants in the rain!
#720 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 23 February 2011 - 08:48 PM
Went to Tescos :)
Edited by Midas Mk1, 24 February 2011 - 03:01 PM.
1 members, 2 guests, 0 anonymous users
    MiniFanGraham
