#7141
Posted 27 November 2017 - 07:47 PM
#7142
Posted 28 November 2017 - 07:28 PM
Spent most of Sunday fitting engine bay bulkhead soundproofing.
Simples, make a cardboard template, cut the mini Spares material to the shape needed and all of the appropriate holes etc and fit.
What a bloddy nightmare. Give me oily bits of metal anytime.
#7143
Posted 28 November 2017 - 10:02 PM
went for drive , broke down
, got towed home
, suspect fuel pump.
#7144
Posted 29 November 2017 - 10:18 AM
#7145
Posted 29 November 2017 - 11:04 AM
went for drive
, broke down
, got towed home
Mechanical or electric pump?
#7146
Posted 29 November 2017 - 04:34 PM
Had a problem with the lights last night, no headlights or main beam just the glimmer of side lights and headlights on half power. Turned out to be the (new) switch - had it to bits and the grease had set like wax insulating the contacts. A quick scrape with a screw driver had them working nice and bright.
#7147
Posted 29 November 2017 - 06:20 PM
#7148
Posted 29 November 2017 - 06:23 PM
I got my mini back today after it being at the resprayers for 2 days. I had the front drivers side wing and both rear quarter panels treated, lacquered and resprayed (also the drivers door done as well where paint bubbled).
Edited by RichMPiBlue, 29 November 2017 - 06:24 PM.
#7149
Posted 30 November 2017 - 05:46 PM
Oil change
#7150
Posted 02 December 2017 - 02:06 PM
Flushed out the heater matrix, removed the heater bypass valve (because it was stuck closed, so now my heater is permanently on) flushed the complete cooling system. Fitted new radiator (Ebay bargain). Fitted new thermostat. Filled with coolant/antifreeze... Still have no heat into cabin..... Dunno what else I can do to resolve it....
#7151
Posted 02 December 2017 - 02:45 PM
Are you sure you have got all the airlocks out of the heater pipework?
#7152
Posted 02 December 2017 - 03:27 PM
Yep 100% sure...
That was my thoughts too, I rigged up the pipework in such a way that when disconnected from the hose, it wouldn't get any airlocks, especially in the heater matrix....
Could do with a coolant pipework map to see Iv got everything connected as it should be... and all pipes are connected the right way round etc....
#7153
Posted 02 December 2017 - 03:42 PM
Yep 100% sure...
The first thing to test is the temp of the heater pipes. Are they both hot for all their length? The cylinder head pipe goes to the top of the matrix.
#7154
Posted 02 December 2017 - 04:06 PM
The heater pipes, 1 gets hot-ish the other is barely warm..... which usually indicates an airlock... but I guarantee that there isnt...
I was going to have a play around with it again today but it started raining ruddy ice so decided to talk to the wife instead.... I'll have a play again tomorrow as I need it for Monday morning, otherwise it'll get a tad cold on me journey LOL
#7155
Posted 02 December 2017 - 04:14 PM
