9729 replies to this topic
#7066 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 October 2017 - 09:04 AM
Spent a nice chunk of money at Calver ST, Keith is an incredibly nice bloke to deal with, would highly recommend.
I've got to agree, I don't live very far from him, if I call in he's always extremely busy but makes time and he's always helpful.
#7067 Zach P-D
Zach P-D
  • 444 posts
Posted 04 October 2017 - 09:33 AM
Indeed, I got further with him in deciding what I want and what is best for what i'm doing in an hour than I did in 2 weeks from other places. That alone tipped the scales in making me purchase from him, that and the quality of his work.
#7068 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 October 2017 - 04:03 PM
MOT passed; no advisories. :D
#7069 panky
panky
  • 1,791 posts
Posted 04 October 2017 - 04:43 PM
Excellent :D
I fitted new tie bar bushes. Aren't them little pinch bolts a swine to move, but they do respond to a good dose of blow torch ;-)
Managed to loose the tool for getting the locking wheel nuts off, I only had it the other day and the cars not moved out of the garage :shy: Spent ages looking for it and yes I checked the door pockets too. Had to devise a method of getting them off with out damaging them and it worked :D . Probably find the flipping thing tomorrow :shy:
#7070 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 October 2017 - 04:48 PM
I replaced mine last week in preparation for the MOT. Same problem, different solution, I put the ball joint splitter on them.
#7071 panky
panky
  • 1,791 posts
Posted 05 October 2017 - 04:31 PM
Flasher unit stopped working the other day so had it to bits and it was full of water O_O Dried it out and it sort of worked but noticed the in-line fuse that fed it was getting very hot. So today fitted new flasher unit and replaced the old fuse holder with a nice new blade type, no more hot fuse and lots of flashy flashy. I've got a few more so I'll do the other three at some point.
The car emerged from the garage after almost two weeks to see what difference the radius arm and tie bar repairs had - it was good :D  Before I did the jobs the handling was weird, constant slight corrections of the steering wheel on bends see-sawing my way round as the back end was trying to steer as well - and that was with only very slight play in the radius arm bearing. Now - go cart again :proud:
#7072 alittleawkward
alittleawkward
  • 34 posts
Posted 05 October 2017 - 04:41 PM
Not today, but last time I touched my car, we drove it about East London for the night! Was so cool having all the attention and being able to see some sights in my lil car, and it was honestly such a reflective drive, because, aside from the never ending line of approaching speed bumps, it was exactly how I imagined I'd spend my late nights with my car. It was pretty perfect.
#7073 YJO
YJO
  • Just Joined
  • 49 posts
Posted 08 October 2017 - 02:37 PM
Jacked up one side to replace the wing indicator fitting and clean muck out of the back of the wheel.. no problem jacking on a new sill...tried the other side..the jacking point collapsed.. this is a new sill fitted by a reputable specialist in the spring and first time used...I will be having serious words tomorrow am!!
#7074 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 08 October 2017 - 02:54 PM
Always jack under the bottom arm on the subframe
#7075 Haygate
Haygate
  • 115 posts
Posted 08 October 2017 - 08:14 PM
Mot yesterday and passed, washed it, dried it and let the sun and wind do its bit then pooped the cover on for the first time today.
Need to lay up properly for winter in the next week or so, luckily its in a nice dry double garage with some airflow under the doors.
#7076 old original
old original
  • 353 posts
Posted 09 October 2017 - 08:17 PM
Got home from a 14 day, 2000+ mile grand tour... Cornwall - Rosslare - Galway - Belfast - Stranraer - Lake district - Peak district - Mildenhall (speedway!) - Cornwall
#7077 Zach P-D
Zach P-D
  • 444 posts
Posted 17 October 2017 - 01:59 PM
fixed my exhaust leak, again.. replaced the 3 different pipes with one Fletcher link pipe, all is good and sounds a bit nicer as it's all SS :)
#7078 Mini Oll
Mini Oll
  • 65 posts
Posted 21 October 2017 - 11:23 PM
Clutch Master Cylinder replacement.
Nightmare job getting the clevis pin out. Followed the advice on here and used an R clip rather than a split pin again. Bled the system and feels great. Test drive tomorrow.
#7079 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 23 October 2017 - 10:28 PM
I topped up the tank before setting off on a long run and topped it up again when I returned. I checked the mileage on the sat nav and it was 205 miles, (nearly all motorway), and sat it at a min 3500 revs. It has 13 inch wheels and a 3.1 diff so that's 70 mph. It took 21 litres to fill it up so I reckon in old money thats about 44 mpg. For a 7 port 1342cc I'm more than happy.
Edited by Northernpower, 24 October 2017 - 09:27 AM.
#7080 imack
imack
  • 2,110 posts
Posted 24 October 2017 - 05:00 AM
Must be a typo, 10 litres is just over 2 gallons, thats nearer 100 mpg.
How's the oil pressure/head gasket issue going?
    Bing (1)
