9712 replies to this topic
#6886 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 03 August 2017 - 12:38 PM
Went to a last minute retro meet with Minifreek  last night..  :D
20526249_10209447761862201_8492016109949
Was a nice meet too, very warm and welcoming if a tad cold by the end of the evening...
Id go again...
#6887 greenmini1275
greenmini1275
  • 348 posts
Posted 03 August 2017 - 01:28 PM
Pulled my carpet out. Bit damp. Was also changing my window winders and snapped a screw in the mechanism. Nightmare, gonna need to get someone to drill it out and then tap it for me. Damn it.
#6888 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 03 August 2017 - 01:35 PM
I too pulled all my carpet out to give it a good clean, a bit damp too. But the floor and sills were all lovely with no signs of repairs whatsoever, unlike my other mini which is currently having work done
#6889 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 03 August 2017 - 01:38 PM
Also fitted some smaller standard seats as the ones that were in there were so high because of the custom subframes.
#6890 Recogniseman
Recogniseman
  • 65 posts
Posted 03 August 2017 - 03:24 PM
Slapped DynoMatt (cheap equivalent) all over the bulkhead, behind the dash.
#6891 Norfolk Boy
Norfolk Boy
  • Just Joined
  • 130 posts
Posted 03 August 2017 - 05:01 PM
Have you had a chance to see/hear if it makes much difference?
#6892 panky
panky
  • 1,789 posts
Posted 03 August 2017 - 05:33 PM
Stripped one side of the suspension to get the cone out. All pretty good except damper is not dampening anything  :shy:
and the cone is dead
What a swine that back bolt is on the retaining plate is to get to :mmkay:
Upper arm and bearings are like new :D
List of stuff has been compiled for the Minispares order.
#6893 Readers14
Readers14
  • 439 posts
Posted 03 August 2017 - 07:09 PM
Finally finished painting my group 2 arches!
After rubbing down, 3 coats of primer, more rubbing down, 4 coats of gloss black, followed by 2 coats of metallic black base coat, more rubbing down & finally 2 coats of clear coat........ I am very much chuffed with the results.
Goes to show preparation & patience is the key to a good finish to painting.
The final base coat is SAAB Jet Black that I had left over in the garage. It's a very subtle metallic black but when it catches the sunlight it looks awesome!
#6894 Recogniseman
Recogniseman
  • 65 posts
Posted 04 August 2017 - 09:35 AM
Not yet. Will put back together tomorrow and let you know. I imagine it will. I did the front floor and put a layer of rubber underlay down and it really helped a lot.
Edited by Recogniseman, 04 August 2017 - 09:39 AM.
#6895 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 05 August 2017 - 03:05 PM
Fitted my new rev counter and it works 👍🏻
https://imgur.com/a/xEdNv
#6896 greenmini1275
greenmini1275
  • 348 posts
Posted 05 August 2017 - 07:16 PM
Put my carpet back in with some closed cell foam added to the back of it. Looks good 😊
#6897 benm
benm
  • 111 posts
Posted 05 August 2017 - 07:22 PM
did some wiring, now the car won start, wooo
#6898 Mat
Mat
  • 254 posts
Posted 06 August 2017 - 08:50 AM
Started taking the engine out, for when the Hornet arrives.
#6899 panky
panky
  • 1,789 posts
Posted 08 August 2017 - 09:57 PM
New doughnuts, dampers etc arrived from Minispares at half one this afternoon.
Old Vs new
By five o'clock I had the passenger side done and the drivers side in bits, cleaned up and the upper arm painted ready to finish off tomorrow.
Bit of a difference
I've actually got some suspension movement now, hopefully the height will settle a bit when driven - the front's got a bit of a Gasser look about it just now :shy:
Edited by panky, 08 August 2017 - 09:58 PM.
#6900 Big Sam
Big Sam
  • 853 posts
Posted 09 August 2017 - 03:11 PM
Attempted to remove the rear subframe, managed to get 1 of 4 of the boot bolts out (and that was by cutting the nut off!).
Going to need a dremel.
