Re-torqued head, checked valve clearances, set idle mixture with a Colourtune plug, added anti-freeze, checked head lamp aim and gave the car his Cooper bonnet badge back Hopefully the MOT place will let me fine tune the idle mixture when it's on the gas analyser and tweak the head lamps, they're usually pretty good like that - oh yes MOT booked for next Wednesday.
#6736
Posted 02 June 2017 - 06:25 PM
#6737
Posted 02 June 2017 - 07:51 PM
Finished stripping engine bay the other day, yesterday completely wire cleaned and sanded the engine bay, inside front wings, front panel and all those hidden nooks and crannies nice and smooth. Then cleaned with a tack rag and panel wipe. Rust treated all those bits of surface rust.
Today, I gave it all the first coat of brush painted Anti Corrosive Epoxy Mastic, except the engine bay which will get a coat of primer after the second coat of epoxy has gone on.
#6738
Posted 02 June 2017 - 09:26 PM
drove it to work for the first time, 17 miles each way, furthest I've ever driven a Mini :)
#6739
Posted 03 June 2017 - 04:03 PM
Got his Cooper face back on
I got the bonnet stripes, side laurels and stripes from an antique and craft centre about ten years ago for less than a fiver - Minispares ones too. Just going with the bonnet stripes for now.
There was never a battery strap fitted so in line with my policy of not spending anything unless I have to I made one
A piece of ally angle I found and couple of cut down tent pegs threaded with a 3/16 whitworth die nut I just happened to have - found a couple of nuts that fitted too - jammy bugger
Need to find the positive battery terminal cover - I've got it somewhere The battery cover is now on so OK for now,
Edited by panky, 03 June 2017 - 04:33 PM.
#6740
Posted 03 June 2017 - 05:33 PM
#6741
Posted 04 June 2017 - 02:31 PM
#6742
Posted 04 June 2017 - 03:49 PM
#6743
Posted 04 June 2017 - 06:12 PM
Probably take her for a evening run.
#6744
Posted 04 June 2017 - 07:26 PM
started my 16v conversion for the first time :)
#6745
Posted 04 June 2017 - 07:28 PM
Pictures?video? make us envious.
#6746
Posted 04 June 2017 - 07:38 PM
Had a fiddle with the engine and started wiring in the alarm.
#6747
Posted 04 June 2017 - 07:44 PM
#6748
Posted 04 June 2017 - 08:44 PM
Looks like I'm gonna spend this week with my head under the bonnet!
#6749
Posted 05 June 2017 - 06:07 PM
Changed the hydraulic brake light switch and then bled the front brakes.
Now Ive got brake lights that work when you just press the brake pedal, not try to stamp it through the bulkhead!
(I actually bought a switch last August and didnt get round to fitting it. Remembered about it about 4 weeks ago and put the switch "somewhere safe", so obviously I couldnt bloody find it and had to buy another one. The original will obviously turn up tomorrow)
Edited by surfblue, 05 June 2017 - 06:09 PM.
#6750
Posted 05 June 2017 - 06:25 PM
Finished wiring in the alarm
