9720 replies to this topic
#6631 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 02 May 2017 - 09:17 PM
Received my two new wings and very nice purple baffled oil catch can.
Fitted catch can and added link pipe to crankcase breather on flywheel housing
Cant fit wings yet.
#6632 RooBoonix
RooBoonix
  • 1,224 posts
Posted 02 May 2017 - 09:46 PM
Got the car home! Now to do some maintenance, finish the engine and get it all going ready for L2B.
#6633 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 02 May 2017 - 09:47 PM
Cant fit wings yet.
Have you any pictures of the catch can?
Edited by Northernpower, 02 May 2017 - 09:48 PM.
#6634 Chris.Williams
Chris.Williams
  • 679 posts
Posted 03 May 2017 - 10:12 AM
Fitted new front screen rubber and chrome fillet strip.
#6635 Chris.Williams
Chris.Williams
  • 679 posts
Posted 03 May 2017 - 10:14 AM
#6636 Rapidmini59
Rapidmini59
  • 195 posts
Posted 03 May 2017 - 04:43 PM
Oil catch can fitted yesterday.
Bought from oz4x4plaza on ebay for £42
Very nice product.
Two internal baffles, one fixed and one removable.
Also has a removable dip stick instead of those unsightly view tubes.
Can remove base by unscrewing to empty when required.
Comes with two jubilee clips, a length of hose and two pairs of fittings 19mm and 25mm.
Made from anodised aircraft ally in a choice of colours
Just for northernpower.
Enjoy
Edited by Rapidmini59, 03 May 2017 - 04:46 PM.
#6637 greenmini1275
greenmini1275
  • 348 posts
Posted 03 May 2017 - 06:57 PM
New roof rack, thanks Mr Bridger.
#6638 Rapidmini59
Rapidmini59
  • 195 posts
Posted 04 May 2017 - 06:02 PM
Fitted and wired up my new led lower front light assemblies on my clubman.
Then replaced all my internal bulbs in rear light clusters for my new led versions.
These were bought from spiyda.com and are the best purchase so far for me.
The rear lights are very simple to change,remove lens,remove a bulb.
Take one new led assembly fit where bulb came from,adjust led pcb to clear the back of the light lens and nip up top fixing nut.
Repeat with the other two bulb/led assemblies.
Then refit lens.
Works very well.
Very bright, has side and brake,indicator and reverse.
Being led's they last a lot longer,much quicker to illuminate and can be seen better.
I have fitted clear lenses so it looks even tidier.
Pics to follows.
Edited by Rapidmini59, 04 May 2017 - 06:10 PM.
#6639 RooBoonix
RooBoonix
  • 1,224 posts
Posted 04 May 2017 - 07:38 PM
Thermostat housing fitted with DSN Retrosport sandwich Plate (needed a new one and the DSN was only £4 more than standard, also means I'll "have" to get the matching top housing) painted a few other brackets and the radiator. Cleaned up inner wings in engine bay and have them a quick spray, cleaned up and kurusted parts of the bulkhead in prep for a lick of paint. Almost ready to chuck the engine in.
Will be changing tyres tomorrow from my old Falkens to Yoko's as the Falkens have well and truly had it. Got 1 new and 3 slightly worn A539s to go on.
#6640 FAZ
FAZ
  • 284 posts
Posted 04 May 2017 - 07:46 PM
recieved a job lot of front suspension stuff from bullmotif, just a shade over 24 hours from order, :)
#6641 Rapidmini59
Rapidmini59
  • 195 posts
Posted 05 May 2017 - 06:23 PM
Today i received the following items.
2 inner cv kits.
2 outer cv kits.
K&n pancake filter.
Facet Fuel pressure reg.
Facet fuel pump.
Powerlite starter motor.
Top and bottom rad hose.
Top and bottom rad brackets and bottom bracket bolt.
11 blade very bright yellow fan.
And then i have fitted cv's to both ends of drive shafts.
Fitted shroud,hoses and brackets to rad.
Attached mounting pillars to fuel pump
Attached mounting bracket to fuel reg.
All for now ready to fit to the beast tommorow.
#6642 ukcooper
ukcooper
  • 1,625 posts
Posted 06 May 2017 - 07:25 PM
moved it 600mm ,so can wash it tomorow
#6643 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 06 May 2017 - 07:28 PM
Refurbished the starter motor to find that the solenoid valve is seized. I have another from a Rover 220 luckily! Apart from that, tucked it up as I won't be working on it until Jun!
#6644 Norfolk Boy
Norfolk Boy
  • Just Joined
  • 130 posts
Posted 06 May 2017 - 08:49 PM
Gave her a quick wipe down then went for a quick spin. Makes me grin like a fool every time
#6645 Woolfie 640
Woolfie 640
  • 52 posts
  • Local Club: Mini Moke club
Posted 06 May 2017 - 10:02 PM
Got the moment through MOT today .No advisories .No bad for a 49 year old motor.
