9720 replies to this topic
#6616 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 28 April 2017 - 02:49 PM
What spares did you order? I've got plugs, leads, fanbelt, dizzy cap and rotor arm (electronic ignition so no points), various screws, cable ties and bodge it tape. I'm thinking fuses would be a good idea but I'm not sure if there should be anything else.
I also take a small roll of electric cable and a spare throttle cable.
#6617 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 28 April 2017 - 02:50 PM
All of those including bodge it tape 😂 Also spare headlight switch and a new relay as mine has played up for ages
#6618 greenmini1275
greenmini1275
  • 348 posts
Posted 28 April 2017 - 04:55 PM
New RC40 and coiled spring conversion.
#6619 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 28 April 2017 - 05:36 PM
How are you finding the coils ?
#6620 Mini Waco
Mini Waco
  • 438 posts
Posted 28 April 2017 - 10:25 PM
Received one of my first Mini Tools - Love getting things from the UK.  Now just have to figure out how to use it.
#6621 Chris.Williams
Chris.Williams
  • 679 posts
Posted 29 April 2017 - 02:50 AM
Have fun!
#6622 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 29 April 2017 - 01:09 PM
Fitted my new osram night breakers 💡💡
#6623 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 29 April 2017 - 01:17 PM
Stripped, cleaned, repainted, regreased and assembled my wiper motor!
#6624 Chris.Williams
Chris.Williams
  • 679 posts
Posted 30 April 2017 - 08:57 PM
Installed my freshly recovered top dash pad, installed the dashboard and wired in 4 new gauges.
Changed my carb needles, adjusted mixture, running much better. Quite bloody well to be fair haha, calling about a dyno session this morning.
Removed front and rear screens for new rubbers and fillet strips.
Swore lots, drunk some beers, in that order.......chowed down on some fish n chips. Great night in the workshop.
#6625 superhuhn
superhuhn
  • 77 posts
  • Local Club: MiniAIX (Aachener Minifreunde)
Posted 30 April 2017 - 09:19 PM
I took her for a ride in the sunshine :mrcool:
Edited by superhuhn, 30 April 2017 - 09:20 PM.
#6626 Shooter63
Shooter63
  • 1,024 posts
Posted 01 May 2017 - 02:33 PM
It's the Mrs mini, but I fitted new rear hilo's, knuckle joints, kyb dampers and sorted out the stupid positive rear camber. Near side went like a dream, the off side was a git, so I cut the cone in half with an angry grinder, jobs a good un
Shooter
#6627 RooBoonix
RooBoonix
  • 1,224 posts
Posted 01 May 2017 - 04:15 PM
Lapped flywheel onto crank and fitted. Fitted wok. Replaced clutch clevis pin. Tapped bypass hole and fitted a plug. Fitted water pump. Fitted radiator bracket and engine mount. Prepared cylinder head for rebuild.
Getting very close now!
#6628 need4speed
need4speed
  • 83 posts
Posted 01 May 2017 - 04:47 PM
Got the overhauled brake calipers back on today.
#6629 CedricTheMini
CedricTheMini
  • 14 posts
Posted 02 May 2017 - 08:49 PM
finally got cedric running sweet as a nut again after much head scratching. big thanks to paul at minicraft kingswood for finding the exact issue and saving me a small fortune in changing parts that didnt need to be changed!
#6630 panky
panky
  • 1,790 posts
Posted 02 May 2017 - 09:02 PM
Re-fitted the wooden dash, I seem to have misplaced one of the brackets and a wing nut :shy:  Also put the door handles back on - I actually found them both :D
