9720 replies to this topic
#6601 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 22 April 2017 - 07:26 PM
Fitted my earlier A+ build into my MPi. Now the fun of fitting the front mounted rad..  :whistling:  :dontgetit:  :errr:
Edited by Midas Mk1, 22 April 2017 - 10:24 PM.
#6602 bensheward
bensheward
  • 200 posts
Posted 22 April 2017 - 09:54 PM
Changed the oil & filters, coolant next weekend before Stratford festival of motoring and more shows in the coming weeks.
#6603 Chris.Williams
Chris.Williams
  • 679 posts
Posted 24 April 2017 - 10:31 AM
Purchased a 1275 shortblock, rebuilt, +30 Pistons, new bearings etc, AEG510 cooper S cam fitted. Oh and that's built, not parts.
All for THIRTY DOLLARS!
That's about £15
#6604 stevedx
stevedx
  • 1,311 posts
  • Local Club: brighton mini club
Posted 24 April 2017 - 10:53 AM
Yesterday, did the inner and outer cv boots on both sides, and greased up all the nipples etc.
Tightened up rear wheel bearings etc.
#6605 panky
panky
  • 1,790 posts
Posted 24 April 2017 - 04:36 PM
Fitted all the lights and put a battery on. Got everything working (once I found a headlamp that went astray :shy: ) but now the hazards have packed up :mmkay:
#6606 greenmini1275
greenmini1275
  • 348 posts
Posted 24 April 2017 - 07:23 PM
Bought a new RC40 to fit and decided to buy a spring conversion for suspension.
#6607 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 24 April 2017 - 07:49 PM
Fitted new 5.6 mm rubber injection fuel pipe to my new 5.65mm copper fuel pipe both ends ready to connect up my facet redtop fuel pump interruptor and facet works regulator for when they arrive.
Drive shafts next
Edited by Rapidmini59, 24 April 2017 - 07:50 PM.
#6608 ukcooper
ukcooper
  • 1,625 posts
Posted 25 April 2017 - 12:29 PM
mot passed
#6609 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 25 April 2017 - 04:18 PM
mot passed
Always a good feeling when you get a new ticket. :D
#6610 mister bridger
mister bridger
  • 911 posts
Posted 25 April 2017 - 04:29 PM
mot passed
Me too!
#6611 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 25 April 2017 - 04:37 PM
mot passed
Me too!
Well that's two of you that'll be feeling smugger than the smuggest smug git in the smug git factory :D
#6612 RichMPiBlue
RichMPiBlue
  • 449 posts
Posted 25 April 2017 - 06:32 PM
Ball joints re-shimmed and some welding done on the offside rear floor + all being sealed.
#6613 panky
panky
  • 1,790 posts
Posted 27 April 2017 - 05:07 PM
Finally got the hazards working :proud:  The flasher unit connector block fell to bits when I prized the unit out, connections where knackered and corroded so made up some new connections and all working. Just one number plate light to replace and that's the elecrics done.
#6614 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 28 April 2017 - 02:22 PM
Mot with no advisorys
Also ordered the just in case spares for the long journey to imm
#6615 Bungleaio
Bungleaio
  • 201 posts
  • Local Club: Not in one.
Posted 28 April 2017 - 02:46 PM
What spares did you order? I've got plugs, leads, fanbelt, dizzy cap and rotor arm (electronic ignition so no points), various screws, cable ties and bodge it tape. I'm thinking fuses would be a good idea but I'm not sure if there should be anything else.
