Fitted new accelerator cable (cheated and just slipped the new inner through ) Heater installed and system filled with water - just a slight drip from one of the heater connections which nipped up. Wet flatted the whole car in preparation for cutting and polishing - soon be shiny
#6571
Posted 13 April 2017 - 04:45 PM
#6572
Posted 13 April 2017 - 08:30 PM
#6573
Posted 14 April 2017 - 03:00 PM
Posted 14 April 2017 - 04:18 PM
Sanding filler, and then sanding some more filler. Sodding pinpricks. Pro Worx filler chaps, its the way forward.
#6575
Posted 14 April 2017 - 08:08 PM
#6576
Posted 14 April 2017 - 10:35 PM
I fitted a new rear fog lamp today.
#6577
Posted 15 April 2017 - 08:22 AM
Today I shall be removing the adjustable camber brackets off the rears, and refitting the standard brackets again....
Maybe refit the Hi-Lo's....
I'll also - hopefully - be polishing the roof because the paints gone a bit dull....
#6578
Posted 15 April 2017 - 07:02 PM
Changed the bypass hose on one of mine....
20170415_165325 by David James, on Flickr
Yup, that needed doing..
Fitted a Minispares EVO waterpump while I was there, seems good so far
20170415_133143 by David James, on Flickr
#6579
Posted 15 April 2017 - 07:05 PM
Also, did my thermostat at the same time... one stud broke despite my best efforts (half an hour winding the bolt left & right a mm at a time..)
20170415_130526 by David James, on Flickr
But, it came out in the end and I could fit new studs & nuts, a new 'stat and gasket- phew!!
20170415_155503 by David James, on Flickr
Seems good after a cheeky test drive
#6580
Posted 15 April 2017 - 09:04 PM
Got a couple of rattle cans on White Diamond and sprayed the roof, not a bad finish if I say so myself. Seems like I'm better with a rattle can than a spray gun
#6581
Posted 16 April 2017 - 04:16 PM
Checked the lights.
Discovered a broken wire on the lighting circuit. Damn!
#6582
Posted 16 April 2017 - 04:39 PM
Ate some chocolate, dug the wheels out and gave them a good clean (note to self - next time don't leave the wheels under the car when you're spraying it ) Ate some more chocolate
#6583
Posted 16 April 2017 - 04:58 PM
#6585
Posted 19 April 2017 - 06:27 PM
Borrowed the wife's steam cleaner to have a go at the seats. They where pretty grubby but they came up great with just the steam and a sponge to wipe the grime away - seats were still dry to the touch when I'd finished. It even took out saggyness in the rear seat base where something had been stored on top of it
