Today I removed these
and replaced them with these
I can't wait to NOT hear them
Posted 10 April 2017 - 04:26 PM
Finished plumbing the engine in and fitted the carb with all pipes and cables connected. Manifold water jacket stubs are corroded so used a piece of copper pipe to by-pass it for now, I'll probably swap it for the Mini Spares one on my Minor as that one isn't connected up to the cooling system.
Posted 10 April 2017 - 09:55 PM
Posted 11 April 2017 - 10:54 AM
Posted 11 April 2017 - 12:25 PM
Posted 11 April 2017 - 03:07 PM
Built up a heater from the three I've got using the oldest matrix of them all - the older ones seem to be more substantial with proper soldered connections instead of the crappy plastic things on the later ones. The fins are a bit knackered but at least it doesn't leak. Also fitted an inertia switch for the Facet pump.
Posted 11 April 2017 - 04:20 PM
looked in the shed and found more bits for fitting well lots more??
Edited by ukcooper, 13 April 2017 - 05:50 PM.
Posted 11 April 2017 - 04:49 PM
Gave it a proper wash and polish ready for the sun.
Posted 11 April 2017 - 07:31 PM
Fitted cam bearings, followers and the camshaft itself. Then fitted the crank and checked the end float. Moving along now...
Posted 12 April 2017 - 08:01 AM
Changed out my flasher unit for a flasher Relay works excellent now
Edited by moolieferret, 12 April 2017 - 08:02 AM.
Posted 13 April 2017 - 03:56 PM
They're helical drop gears. I removed the straight cut drops and can't believe the difference. My ears don't bleed at 7,000 revs anymore. The only mistake I made was fitting them in the car; if I could have got hold of an engine hoist it would have been quicker to remove the engine. I bought them from John at Guessworks.
