Finished cleaning up the chambers in my cylinder head and washed it out. Pulled in 1 cam bearing, second one I wasn't paying attention and I made it a bit less round than it should be, 3rd I didn't bother as I am going to turn up some proper tools to pull them in with.
#6526
Posted 31 March 2017 - 05:52 PM
#6527
Posted 31 March 2017 - 06:07 PM
Torqued the head up, set valve clearances fitted the side engine stabilisers. fitted manifolds and lost the bolts for the clutch housing breather
#6528
Posted 01 April 2017 - 09:26 AM
#6529
Posted 01 April 2017 - 07:09 PM
#6530
Posted 02 April 2017 - 05:45 PM
Passed mot, taxed and went for a spin
Excellent
Found that the clutch cover bolts are the same thread as the breather can ones so cut a couple of spare ones down and fitted. Gear change rods fitted, thermostat housing cleaned up but found the thermostat was slow to open and barely came off it's seat - new one ordered. Brake calipers and drums painted with green engine enamel, cant find the bottom near side engine steady - I'll probably trip over it tomorrow
The heater off-take stub had corroded so I searched around and found a couple of bits to make one. The flange came off the heater connection on my Minor when I fitted a 12G940 head and the brass stub is part of a heater off-take from a Commer engine, it fitted into the hole in the flange perfectly
Haven't done any solver soldering for years but I managed ti stick the two bits together
Saved a few pennies
#6531
Posted 02 April 2017 - 06:29 PM
#6532
Posted 02 April 2017 - 07:53 PM
Decided to tighten my sump bolt only to find its torn the thread from my gearbox.... bums!
#6533
Posted 03 April 2017 - 03:27 PM
Fitted adjustable camber brackets on rear...
Fitted lockable bonnet pins (Iv had for ages just never fitted them... not 100% if I like them, so ordered some normal bonnet pins just in case...
#6534
Posted 03 April 2017 - 04:23 PM
new sump plug.
And presumably more oil
#6535
Posted 03 April 2017 - 07:04 PM
spent more money and the mini's disappeared ? should be back Thursday I hope
mini spares no longer available
and a treat
Edited by ukcooper, 03 April 2017 - 07:09 PM.
#6536
Posted 03 April 2017 - 08:28 PM
Just to trailer it over. Will get my screen rubbers done to, front one leaks.
#6537
Posted 03 April 2017 - 11:13 PM
Actually drove to MiniSpares as i wanted bits today!
Fitted Fog lamps and wired in to new toggle switch under dash rail
Fitted new fuel pipes and filter to bulkhead
Made new wash jet lines and fitted
Wired in a Voltmeter and fitted under dash rail
Fixed my fuel cap and fitted an Aston one
Test fitted new dash cards etc
#6538
Posted 04 April 2017 - 08:23 AM
Also fitted new headlight bowls and headlights.
Test fit my grill
#6539
Posted 04 April 2017 - 06:09 PM
Fitted new inner CV joint to the near side (couldn't get the old one off the knackered gearbox ) Then buttoned up both hubs, greased it up and had a bit of a tidy round. Only missing three sockets
#6540
Posted 06 April 2017 - 08:48 AM
Bing (2)
