9720 replies to this topic
#6511 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 26 March 2017 - 09:51 PM
For the first time since early 2010 I went out for a drive in my mini for no real reason.
The rebuild of my car started early last year it has only done a few miles but today I went out for a proper drive to give it a bit of a shakedown. I did 75 miles and I only had to stop to reconnect a speaker wire to the amp.
I seem to have an issue that when I flash the main beam the radio cuts out but if thats all I've got to sort then I'm very happy.
I have the exact same issue with my radio!
#6512 minimans
minimans
  • 411 posts
Posted 26 March 2017 - 09:58 PM
I Ordered new valves and a 649 camshaft for my Arden 8 Port today...................Ouch is all I can say right now....................must remember to buy more Vaseline...........
#6513 RooBoonix
RooBoonix
  • 1,224 posts
Posted 26 March 2017 - 10:19 PM
Fitted idler bearing and first motion race to transfer case, and fitted idler bearing to gearbox case. Cleaned up main caps and measured the newly ground crank, pleased to say it's bang on spec. Trial fitted crank but need to re-fit after measuring my thrust washers so I know what I need to buy to set the right end float.
#6514 SuperDeLuxeNick
SuperDeLuxeNick
  • 615 posts
  • Local Club: West Country Minis
Posted 27 March 2017 - 07:23 PM
Fitted clutch clave cylinder and master, bled system and took it for a quick run around the block after its winter break!
#6515 Chris.Williams
Chris.Williams
  • 679 posts
Posted 28 March 2017 - 10:13 AM
Fitted my engine finally.....then broke a head stud while tightening them down. They were new ones to. Groan. 🙄
Attached File  image.jpeg   54.71K   13 downloads
Attached File  image.jpeg   67.31K   7 downloads
Attached File  image.jpeg   65.45K   13 downloads
Edited by Chris.Williams, 28 March 2017 - 10:13 AM.
#6516 RooBoonix
RooBoonix
  • 1,224 posts
Posted 28 March 2017 - 10:34 AM
Somebody else recently had an issue with a headstud breaking... weird.
#6517 Chris.Williams
Chris.Williams
  • 679 posts
Posted 28 March 2017 - 06:48 PM
Fitted my engine finally.....then broke a head stud while tightening them down. They were new ones to. Groan. attachicon.gifimage.jpegattachicon.gifimage.jpegattachicon.gifimage.jpeg
Minispares ones? I think I remember seeing something about that to.
Lucky I have a set of ARP studs I was saving for a race motor. Guess I'll use those.
Sometimes feel like we get sent the rubbish items cause we're on the other side of the planet. It's not the first time. Paranoia maybe lol
#6518 panky
panky
  • 1,790 posts
Posted 28 March 2017 - 07:18 PM
Seam sealed around the floor repairs the other day so today I painted the floor. Then started preparing to drop the engine back in :D
#6519 panky
panky
  • 1,790 posts
Posted 29 March 2017 - 03:17 PM
It's in. Mounting bolts AAAHHHHHGGGGGGGGGGGGGGGG
#6520 Mito
Mito
  • 415 posts
Posted 30 March 2017 - 02:15 PM
Set fire to the wiring harness!!!!
#6521 lordyoung1980
lordyoung1980
  • 97 posts
Posted 30 March 2017 - 04:15 PM
Removed some bits from the engine today ready for cleaning up and painting. I want to paint the engine gold to contrast against the black bodywork. Stripped off the paint from the top of the radiator for polishing.
#6522 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 30 March 2017 - 04:26 PM
Sanding filler, oh the joys.
#6523 ClassicAsh
ClassicAsh
  • 139 posts
Posted 31 March 2017 - 03:31 PM
decided to change the cable ties for the correct metal clips on the CV boots, what a struggle that was ! stiff neck and aching arms now. and I only fitted one !
#6524 mister bridger
mister bridger
  • 911 posts
Posted 31 March 2017 - 03:45 PM
Replaced drivers side rear knuckle joint as the car was sitting rather low on that corner. Could find absolutely nothing wrong with the old one, yet with the new one fitted it sits perfectly. Identical type of knuckle joints too. Weird!
#6525 scrumpix
scrumpix
  • 453 posts
  • Local Club: Yeovil Mini Mania
Posted 31 March 2017 - 04:12 PM
new sump plug.
50 user(s) are reading this topic
0 members, 50 guests, 0 anonymous users
