9720 replies to this topic
#6316 mina08
mina08
  • 255 posts
Posted 08 January 2017 - 07:12 AM
Cleaned all the carbon off the pistons, bores and combustion cambers
#6317 benm
benm
  • 111 posts
Posted 08 January 2017 - 09:24 AM
Rebuild suspension, plumbed in rear brakes, bolted in new brake MC refitted engine and made more of the exhaust 😀
#6318 Stu.
Stu.
  • 912 posts
Posted 08 January 2017 - 10:44 AM
Adjusted the tracking on my 850  :gimme:
#6319 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 09 January 2017 - 11:37 AM
Treated it to some very comfy seats I bought yesterday off a member...
Need to find a leather rear seat now....
#6320 haydenuk
haydenuk
    Starting My Mini Up
  • 1 posts
Posted 11 January 2017 - 09:40 PM
Building a mk3 classic mini but due to Honda b18 engine i will be putting in as well as supercharger and lightweight pistons the hp will be signally greater than the standard mini engines in excess of 350bhp therefore meaning that the useable wheel horse power will be decreased due to low friction on standard mini sized wheels. I wanted to upgrade to a 15inch wheel will this drastically affect the driving of the car, camber and offset? anybody got any advice on wheel size and setting up to increase friction and therefore useable wheel horsepower
#6321 Chris.Williams
Chris.Williams
  • 679 posts
Posted 12 January 2017 - 04:51 AM
Ordered a new piston set, and looking into MS Evolution cams.
#6322 Chris.Williams
Chris.Williams
  • 679 posts
Posted 12 January 2017 - 07:13 AM
Just ordered a lightened flywheel from mini spares. The road going version.
#6323 panky
panky
  • 1,790 posts
Posted 13 January 2017 - 07:32 PM
Fitted centre strap, torqued up mains and big ends, front plate and timing gear fitted, buttoned up engine to gearbox, oil pump cam and dizzy drive in, re-set the valve timing to match the MG cam - with 2 degree advance thrown in. Actually done over two days - getting there :D
#6324 minifreek1
minifreek1
  • 1,260 posts
Posted 13 January 2017 - 09:12 PM
Removed the normal foglight and replaced with a foglight off a Fiesta Mk1, to give it a stealthy look..... fortunately the profile of the Fiesta foglight fits the rear valance almost perfectly.....
Removed the reverse light from the rear valance and installed a spotlamp to the bootlid to use as the reverse light instead, was looking for a Lucas unit but  none have come up for sale in my price range as yet...
Replaced the cardboard liner things that go into the rear bins, bought them a couple months ago and only just got round to fitting them, had to cut them to fit around the rollcage....
Swapped a front spotlamp that had filled up with water, rusty water.... found out that the rear bowl isnt exactly waterproof and water had got to a level that it was seeping into the spotlamp itself via the bulb holder.... when I removed the lense about a pint of water poured out.... was a bit of a surprise because the water was ruddy cold... LOL
#6325 old original
old original
  • 353 posts
Posted 14 January 2017 - 05:38 PM
new manifold gasket, now all I need is a new back....
#6326 greenmini1275
greenmini1275
  • 348 posts
Posted 14 January 2017 - 07:37 PM
Ordered all new windscreen wiper components for a complete change of everything.
#6327 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 14 January 2017 - 08:10 PM
Tried to find the cause of the oil leak i've accumulated, either the gear linkage connection, or timing case cover..  :goaway:  >_<
Tomorrow is the time to find out.  >_<  O_O
#6328 minifreek1
minifreek1
  • 1,260 posts
Posted 14 January 2017 - 09:15 PM
You gonna get wet and cold tomorrow......
Tomorrow, Im fitting shelves so will be dry and warm.....
#6329 Midas Mk1
Midas Mk1
  • 5,774 posts
Posted 14 January 2017 - 11:35 PM
Will be in the garage, just hope the oil leak is something simple on the linkage aha! Put loads of sealant on the engine gaskets so stumped as to why it's leaking aha
Make sure those shelves are strong, don't want anything falling off onto the mini :)
#6330 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 14 January 2017 - 11:49 PM
Nothing as i dont own one.
However insulated and boarded my garage cieling and new lights just incase i get another.
