9973 replies to this topic
#616 Andywade
Andywade
  • 328 posts
Posted 08 January 2011 - 10:43 AM
picked it up from east anglian mini center where they fixed the electrics which are a shambles!
took them 5 1/2 hours to check all the 'lectrics and fix the sidelights which were not working and generally sort the electrics out so they wont catch fire.
new battery and £365, But i did get some stickers!!!!
bloody hell, you could of fitted a new loom for half of that
They did say I'd need a new loom at some point and that it would be a couple of days work - how long do you think it would take for me to do it all myself? I have the wiring diagram. from the haynes manual (would be nice if they did it in colour though)
#617 se_juggles
se_juggles
  • 1,043 posts
Posted 08 January 2011 - 10:45 AM
bout to go de seam the rear valence hopefully :techsupport:
#618 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 08 January 2011 - 10:46 AM
ive just spent from 5am rebuilding left side hub to relise i got given the wrong taper roller bearing ): the old ones took for ever to take out
#619 Miniboy-NL
Miniboy-NL
  • 134 posts
  • Local Club: mini 7 club nl
Posted 08 January 2011 - 11:21 AM
we try to get the engian 100% bud we dident get is good
#620 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 08 January 2011 - 11:27 AM
Not done any yet today but will be fabricating a new lower radiator bracket and do some scale drawings for the machinist
#621 MiniSal
MiniSal
  • 219 posts
Posted 08 January 2011 - 05:33 PM
Broke the wretched thing- the heater valve on Mk2 Cooper went this afternon, spraying coolant all over the electrics- solenoid, coil, distributor etc.
#622 steverose
steverose
  • 229 posts
Posted 08 January 2011 - 06:09 PM
Got loads of stickers put on. Got an oil and filter change as well as changing the brake fluid planned for tmrw. Then she will be ready for a track outing :teehee:
#623 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 08 January 2011 - 06:21 PM
Went to my Coventry Uni interview in it :teehee: , and fitted the chrome arch trim :)
#624 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 08 January 2011 - 06:33 PM
Tore up south Leicestershire. Lovely sunny day.
#625 steverose
steverose
  • 229 posts
Posted 12 January 2011 - 08:35 PM
Just put a load of stickers on, its now starting to look lilke a race car ;)
#626 Mike92
Mike92
    Previously known as PoweRMikE.
  • 337 posts
  • Local Club: South Devon Mini Club
Posted 14 January 2011 - 12:29 PM
Put some new HT leads on it. Now starts on the key :).
#627 Chris_R
Chris_R
  • 399 posts
Posted 14 January 2011 - 12:31 PM
Wet & dry sanded the bonnet and wings where angle grinding 'dust' has rusted onto it then fitted new chrome handle set.
#628 mattdc2r
mattdc2r
  • 1,296 posts
  • Local Club: Not yet!
Posted 16 January 2011 - 07:56 PM
She's not been out for a run since early October. Popped out and she started up first time and purred like a kitten.
Actually that is a lie. Totally flattened a fully charged battery pack, so went and got the other car. Had jump leads connected for over an hour before she finally fired. Removed dizzy cap, plugs, leads etc etc and wiped them all down. Was a spark, but it was a bit weak. Think it just took a while to get the fuel in there. Finally fired and I took her for a spin. Bit lumpy and occasionally bogged down. Gonna whip all plugs out and give them a little clean later in the week, as well as remove the k&n filter and give it a proper clean. Think she's just running a little rich at the minute.
#629 OllieTheWelder
OllieTheWelder
  • 636 posts
Posted 16 January 2011 - 08:00 PM
Fitted new grille, Took wheels of the mini sprayed them white :)!
#630 secondopsman
secondopsman
  • 661 posts
Posted 16 January 2011 - 08:09 PM
Took the vauxhall x16xe 16v engine out and swapped it for a c16xes engine (more power and torque) only to find the radiator is no good.
