9720 replies to this topic
#6241 greenmini1275
greenmini1275
  • 348 posts
Posted 24 November 2016 - 12:06 PM
Full service. Oil filter, oil change, air filter, plugs, leads, dizzy cap. Runs like a frickin dream now.
Paul
#6242 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 27 November 2016 - 08:01 PM
sold one :ermm: and  got my lights fitted and working :gimme:
#6243 JCP
JCP
  • 74 posts
Posted 27 November 2016 - 08:06 PM
Removed a LOT of cardboard and filler (courtesy of some previous owner with a flair for danger) and began the long process of welding in new panels.
#6244 Sag
Sag
  • 59 posts
Posted 27 November 2016 - 08:32 PM
Put 8liters of waxoil on after a week of prepping the body,got inside next,looks like new now again.
#6245 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 November 2016 - 08:54 PM
Put it up on axle stands tried to take the wheels off - see thread on spinning studs - swapped the boggo dampers for KYB Adjust-a-rides and wired in my trickle charger.
Replaced light clusters, took off the dash and moved the fan thermostat that was hanging down behind the dash, removed the face-missing headunit and a load of associated wiring from behind the dash.  Replaced the indicator stalk, which meant taking off the steering wheel, which meant taking out the steering column - total ball-ache!
Was going to do a few other bits, but it took two jacks and most of an F1 race to get the fuel tank back in!
Discovered there's a towbar and electrics installed underneath, just missing a swan-neck tow ball and a tiny caravan!
Next job is removing the mechanic fuel pump and fitting a blanking plate, then there's oil leaks to look at.  Once that's done everything's to grease, new oil filter and oil etc.  But no rush as the weather is unlikely to be decent again for a while now...
#6246 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 27 November 2016 - 10:12 PM
Turned on so many heaters I blew the fuse to the garage so packed up and went back in.
Been there, done that when spraying my Mini a couple of years ago.
Ps when plugging two heaters into an extension reel - always unwind it fully so it doesn't become one solid ring of useless wire 😳
#6247 RooBoonix
RooBoonix
  • 1,224 posts
Posted 27 November 2016 - 10:33 PM
Removed transfer casing, timing gears and split the engine and gearbox. Next on the list is whatever I feel like doing!
#6248 brownspeed
brownspeed
  • 451 posts
Posted 29 November 2016 - 06:50 PM
new battery. :(  :(  :(
#6249 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 29 November 2016 - 07:15 PM
Ordered a set of eyebolts and spreader plates so I can fit my harness....
Looked on Ebay for a pair of bucket seats and theres a pair on there, not that far from me, but no spare pennies because someone didnt buy what they was supposed to be doing.... Grrrrr
#6250 mattmiglia
mattmiglia
  • 515 posts
Posted 29 November 2016 - 10:47 PM
These were all into wall sockets but it was 1 oil radiator, 2 halogen heaters and 1 fan heater 😬
#6251 ClassicAsh
ClassicAsh
  • 139 posts
Posted 30 November 2016 - 03:40 PM
fitted rear retractable seat belts, which involved making some retaining plates up and welding them in place. I am very happy with the results too, no more messing about with those bloody awful fixed belts and the kids will be happy.
#6252 dasupersprint
dasupersprint
  • 848 posts
Posted 30 November 2016 - 08:23 PM
Nothing! Kids and wife are sick and preventing me from working on the Mini...
#6253 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 30 November 2016 - 09:40 PM
Refurbed my wiper motor, tubes and put on new wheel box's and a drive cable. Nice and shiny with new paint
#6254 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 01 December 2016 - 01:12 PM
Tuesday night the indicator circuit inline fuse decided it would blow, I had to temporarily use a 35 amp fuse, so replace that with a 15 amp item. Last night Greased both rear wheel bearings and adjusted the rear brakes a bit(handbrake was at 5 clicks instead of 3) so adjusted up a bit, it now holds lol
#6255 panky
panky
  • 1,790 posts
Posted 01 December 2016 - 04:48 PM
Decided I was fed up climbing over and around stuff  in the back of the garage so started a marathon clean and tidy up, back on it tomorrow too.
