9977 replies to this topic
#361 minilester
minilester
  • 770 posts
Posted 20 November 2010 - 04:29 PM
looked on different mini shop websites as work is giving me £250 to spend as a prezzie... just not sure "window shopping" counts...
#362 MrSporty
MrSporty
  • 75 posts
Posted 20 November 2010 - 04:37 PM
Today i made a start on fitting my megajolt setup.
Went out and grabbed the last few bits i needed. A set of fiesta HT leads and some 1/8" tubing for the vac takeoff
Took out the rad and figured it was easier NOT to disconnect the bottom hose but just pop it off the water pump, it gives enough to be able to lift the rad out of the way.
Found out that even with the car in 4th gear i couldn't free the crank pully bolt. I couldn't get the breaker bar on easy and the comedy spanner was just bouncing around so off came the starter motor so i could jam a screwdriver in the ring gear.
Also found that my 998 wasn't fitted with the damper style pully so the one i machined to fit the trigger wheel wasa bit of a pain to get on even with the engine mount loose. Took the easy way out and trimmed the bracket a bit more square with my grinder.
Finally knocked up the parts for the bracket out of some scrap steel. Doesn't look too bad with an easy to get to hex capped bolt. It will be mounted to the same bolts as the engine mount so it should be nice and solid.
Tomorrow is welding time and reassembly
#363 Cerberus
Cerberus
  • 989 posts
Posted 20 November 2010 - 05:04 PM
Took my rear cones/trumpets out ready to fit new cones and HILOs.
Painted some spots of rust on the subframe.
That's taken from 12 till now, >_<.
#364 Ipod
Ipod
  • 2,024 posts
Posted 20 November 2010 - 05:45 PM
you can buy me a 52mm TB, for my mpi, if ya like >_<
#365 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 20 November 2010 - 07:22 PM
today i removed chloe's engine >_<
#366 minilester
minilester
  • 770 posts
Posted 20 November 2010 - 09:39 PM
you can buy me a 52mm TB, for my mpi, if ya like :thumbsup:
no problem just give me the difference from what ever i go over the 250 with at the mo its... £216... so give me that and i'll include it in the shopping list :(
#367 1984mini25
1984mini25
  • 8,850 posts
Posted 20 November 2010 - 09:43 PM
Re-fitted some fog lamps under the bumper on the 25 in the fog/mist, only to discover I’ve run out of long enough lengths of wire to connect them all up. :(
#368 shed
shed
  • 594 posts
  • Local Club: Lsdyruivy
Posted 20 November 2010 - 09:50 PM
changed barrel in drivers door so i can lock lock it :( just need to do the other door and boot so only need 1 key but its an ongoing project, cant rush these things :thumbsup:
#369 ashley 2008
ashley 2008
  • 115 posts
  • Local Club: Eastbourne mini Club
Posted 20 November 2010 - 09:52 PM
i have had the engine out and fitted new gearbox and engine back in now. just few bit to do tommow
#370 camp freddy
camp freddy
  • 3,696 posts
Posted 20 November 2010 - 10:11 PM
gave the repaired wheel arch a coat rattle can top coat to seal it until I get the
garage sorted to spray it properly
#371 retroracer1275
retroracer1275
  • 543 posts
Posted 20 November 2010 - 10:33 PM
i got £100 for what was left of the my crashed mini :'(
#372 union jack
union jack
  • 111 posts
Posted 20 November 2010 - 10:38 PM
Drove it to Gorleston, walked dog along links road then returned home & put it away in the garage :(
#373 Ipod
Ipod
  • 2,024 posts
Posted 20 November 2010 - 10:57 PM
Sweet so if i give you £100 youll buy it for me.....shweet..no going back on the deal...the dangerweb saw it all :gimme:
#374 minilester
minilester
  • 770 posts
Posted 20 November 2010 - 11:33 PM
.. no i mean im already £216 over the £250...so £466 minus your hundred... this aint working.. anyone else want to give me money?
#375 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 21 November 2010 - 12:40 AM
Fitted my carpeting, windows and seats. Now awaiting the arrival of my beautiful new walnut dashboard, I love it when a build comes together :( :thumbsup:
