9720 replies to this topic
#2236 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 19 July 2012 - 02:50 PM
Parts finally arrived soo...
New thermostat
New thermostat housing gasket and bolts
Re-assembled hoses/pipes
Test Drive :)
Still running hot so will give her a good drive tomorrow and see how hot she gets.
Checked for any cold spots in the pipes? :-)
She seems ok now. But needs a good run out I think. Might change the rad in the winter when I do my flip front
Yeah could be a good idea, rad flush would be a bad idea either :D
#2237 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 19 July 2012 - 03:14 PM
I did the whole attached hose pipe and flush but didn't use any products. Wondering about the water pump. Don't know how big a job it is.
#2238 minimuk
minimuk
  • 1,946 posts
Posted 19 July 2012 - 03:59 PM
got MUK ready for MOT tmz, greased all nipples topped all up adjust brakes checke lights checked rad and oil CO2 emmision ....should go through no probs.....will see :shades:
And yes he passed MOT again.....another year pleasure.... :highfive:
#2239 666junky
666junky
  • 1,225 posts
Posted 19 July 2012 - 04:59 PM
Drove her.. going over a bump i smacked my coxyx against the bar going across the bottom of the chair (standard seats)
Now hating her. :(
#2240 twink
twink
  • 337 posts
Posted 19 July 2012 - 05:04 PM
Left it well alone, so at least I haven't made it any worse!
#2241 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 19 July 2012 - 05:10 PM
Now hating her. :(
What a pain in the arse! :lol:
I fitted a braided oil line in place of the leaking olive connection thing plus a new pressure sender. Then got slightly concerned it now takes a few seconds for the oil pressure light to go out, so hooked up my new oil pressure gauge and found what I suspect is a healthy 32psi at idle.
Still not sure why the light doesn't go out right away though...
Then I started painting somethings.
#2242 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 19 July 2012 - 05:15 PM
Gave it a wash and detail
#2243 Jaswalker24
Jaswalker24
  • 113 posts
Posted 19 July 2012 - 05:44 PM
secured the battery cable back into the guttering and tightened all the screws on the door handles :)
#2244 milkybar.kid
milkybar.kid
  • 146 posts
Posted 19 July 2012 - 06:44 PM
washed her
#2245 Equinox_Monty
Equinox_Monty
  • 20 posts
Posted 19 July 2012 - 08:37 PM
Removed wheel arch spats to assess degree of rust. Pleasantly surprised.
A good wash to see what other bodywork stuff needs doing and thats it!
#2246 animale
animale
  • 160 posts
  • Local Club: Minis n Oatcakes
Posted 19 July 2012 - 08:45 PM
Replaced my fuel line and fuel filter. Fiddle job.
And removed sportspack arches from rear of the car. Found out I have hi-Los on the rear, bonus but found a big chunk of rust on rear valance and valance cover. OUCH
#2247 minimuk
minimuk
  • 1,946 posts
Posted 20 July 2012 - 11:34 PM
used 1 can Dinitrol on MUK tday, cavety's, inner sill's, A post's, front bulkhead ends, scuttle ends, rear valance ends, bottum door's... one can gone.......rust prevention in place for a bit again.... ;D
#2248 o0OWILKSO0o
o0OWILKSO0o
  • 381 posts
Posted 21 July 2012 - 05:59 PM
Actually did some work on her today, fixed the leaking bottom hose, cutt away unused loom ends and blanked off cables with heatshrink, fixed cable and connectors on electric fan. However in doing all of this i found that when the engine was swapped (mpi to carb + dizzy) the radiator no longer fitted where it was suposed to and was CABLE TIED on! So I had to cutt out part of the front end to get it to sit properly and now need proper mounting brackets.
#2249 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 21 July 2012 - 06:04 PM
waxoyled the flitch/sill joining area and the welded joints of the rear subframe
#2250 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 21 July 2012 - 09:05 PM
Torqued down the new head, tweaked the tappets, then trashed the nuts off it. Happy days!
39 user(s) are reading this topic
0 members, 39 guests, 0 anonymous users
