9713 replies to this topic
#1936 Se7enS1ns
Se7enS1ns
  • 472 posts
Posted 09 May 2012 - 08:23 AM
I tried to change out the rear brake cylinders/shoes on my mini, as the rear cyl. was leaking slowly, everything was wet inside the drum, when I tried to loosen the brake line from the brake cylinder, it just twisted off
Unfortunately that happens more often than not, especially with steel brake lines. The very same thing happened to me yesterday - luckily I have some spare brake pipe and a cutter / flarer tool. Although I'll be honest, I didn't use any of that... I just stole the pipe from my laid up mini...
#1937 twink
twink
  • 337 posts
Posted 10 May 2012 - 07:28 AM
Admit defeat and phone a mechanic
#1938 Brad_Raybould
Brad_Raybould
  • 421 posts
  • Local Club: Bostin' Mini Club
Posted 10 May 2012 - 11:30 AM
Well, it wasn't today but I fitted my new air horn on Monday morning. So much louder and better :D
#1939 twink
twink
  • 337 posts
Posted 14 May 2012 - 07:55 AM
Taken it to the garage :-(
#1940 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 14 May 2012 - 09:44 AM
Gave the cooper a good clean and polish
Tried some Dodo Juice polish out, seems to go on nice (and smells good), but was hard work :P Beaded up nice this morning in the rain >_<
#1941 Udo
Udo
  • 1,670 posts
Posted 14 May 2012 - 10:05 AM
Got it started for the first time in 3 years! long long story!
Nice to hear the noise again - although got to get timing sorted as theres a bit of a backfire >_<
#1942 JP Detailing
JP Detailing
  • 308 posts
  • Local Club: A's Of Herts
Posted 14 May 2012 - 10:24 AM
Do you mean wax?
Try 3 layers of Dodo Purple Haze, will work a treat on that dark paintwork :D Long time beading with a super glossy finish.
#1943 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 14 May 2012 - 01:49 PM
wax - polish all the same to me. stuff you stick on your paint to make it shinier ;)
#1944 JP Detailing
JP Detailing
  • 308 posts
Posted 14 May 2012 - 03:23 PM
hahahaha. But you could make it shiner-er-er-er :D :w00t: Although it looks great already!
Edited by JP Detailing, 14 May 2012 - 03:28 PM.
#1945 richw911
richw911
  • 2,084 posts
Posted 14 May 2012 - 03:29 PM
True but Wax will protect your paint work from bird dropping and tree sap ect .
Yeah the purple haze is good but try Collinite 845 insulator wax its amazing and liquid so easy to apply :proud:
#1946 JP Detailing
JP Detailing
  • 308 posts
Posted 14 May 2012 - 04:03 PM
Couldnt agree more, protection is very important. Esp with a Mini thats prone to rusting. Good protection will prolong the life of your paint. I prefer hard waxes for the body and then the liquid (like the one of suggested) for door shuts and hard to reach places (an often neglected and very important part that rusts of the body).
Anyway, we digress. Back on topic - Today I sorted out a short in my rear speakers. Now I can listen to music again. Woop!
#1947 TA2DMAC
TA2DMAC
  • 755 posts
  • Local Club: Michigan MINI Motorin Club
Posted 14 May 2012 - 07:32 PM
Today I took picks of the car for the Insurance company. I'm hoping to have it on the road before this weekend. I'm so itching to go for a nice long drive in it.
#1948 Monkeymuff
Monkeymuff
  • 68 posts
Posted 14 May 2012 - 07:53 PM
Fitted a works style bonnet strap
and a Lucas boot lamp
#1949 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 14 May 2012 - 07:57 PM
New 74 degree thermostat, cooling system flush, adjusted the rear brakes and a grease at all the suspension points ready for L2b! :D
#1950 waynosworld
waynosworld
  • 13 posts
Posted 15 May 2012 - 05:56 AM
Well, it wasn't today, but this weekend I put all new rear brake cylinders/shoes on the mini, actually I removed the driverside last week, but when I tried to remove the brake line off the brake cylinder, it just twisted off, so I had to wait for more parts.
I now have a e-brake again, and the brake pedal is right on the top now.
I did have an issue though, when I tried ajusting the brakes in the rear, the ajuster bolt(if that's what it is called), seemed to strip, so basicly either the shoes were really tight because I forced the ajuster in with a bar, or they are loose, which doesn't seem to effect the pedal height at all, so I will leave it alone, and check into more new part/parts, do one, do both, although I bought two new rear brake lines, the other side came off easy, so I left the old one on it, and now have an extra.
I did have another issue also, the brake cylinders I received had the dowel pin on the wrong side, so I had to remove it from both brake cylinders so I could get the clips on, is this really bad?
Fact is, the driverside had no clip holding it on, and the dowel pin was removed on it also, did I receive the wrong parts?
I thought it was really strange that the bleeder is on the bottom of these brake cylinders, but they seemed to bleed properly, and the pedal is not soft, so I am assuming I got all the air out of the lines, it's really weird having the bleeder on the bottom, I have never seen anything with the beeder on the bottom before.
wayno
