9719 replies to this topic
#151 midridge2
midridge2
  • 1,794 posts
Posted 24 June 2010 - 09:11 AM
yesterday i removed the rear subframe, 2 hours from start to finish, all heel board bolts came straight out and not a spot of rust on the threads.
rear mounts bolts were solid, had to snap 3 of them to get off.
spent the rest of the day stripping the bits off the frame and cleaning them up and stripping the rust off and priming and painting them, next job today reassemble the new/second hand subby (ebay buy, £9) then cut out 3 areas in the boot floor and weld patches in and then decide if to replace the wheel arch or patch it.
#152 Ipod
Ipod
  • 2,024 posts
Posted 24 June 2010 - 01:55 PM
I drove to work at 5am.....then drove home just now, windows down Korn on the music box.....happy sunny day :D
Apart from sitting at lights with music that would send the swear filter on here into overdrive....and watching other peeps do thier windows up....inconciderate.....yes, :thumbsup:
Edited by Ipod, 24 June 2010 - 01:55 PM.
#153 Mr Duck
Mr Duck
  • 224 posts
  • Local Club: Clubless!
Posted 24 June 2010 - 03:35 PM
I got my rear cones & trumpets replaced with some shiny new Hi-Lo's - it's been a work in progress for some time but once I'd got the technique down, it wasn't such a long job after all! :D
#154 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 24 June 2010 - 04:26 PM
Had mine crashed into :D :thumbsup:
#155 miniman.matt
miniman.matt
  • 495 posts
Posted 24 June 2010 - 04:56 PM
Well its a long list even so all this done and the car is up and running again, i only started at 11.30 :D
-Oil pump
-Cam belt
-Alternator belt
-Plugs
-Leads
-Dizzy cap
-Oil filter
-Oil change
-Coolant change
-Top and bottom ball joints
-Grease all nipples
Dinner well earned lol
#156 mars red mike
mars red mike
  • 1,500 posts
Posted 11 July 2010 - 08:54 PM
Had quite a good day on the mini today and got a fair few jobs done.
Replaced the passenger side driveshaft and inner cv joint. Seems to have cured (fingers crossed) the annoying clunk that I was
getting when drive was taken up. Replaced both gaiters, reshimmed the ball joints, regreased everything. While I was at it I finally fitted
my slotted discs and EBC Black Stuff pads that have been sat in the shed since I broke my old mini up.
Fitted my chromed gearbox steady on the passenger side but forgot to take a picture :) While i was doing this I thought Ill just check the bolts on the
other steady. Good job I did as the bolts that hold the bracket on had somehow worked loose and was rattling around a fair bit so sorted that out while I was
underneath. Gave the exhaust a coat of hi-temp paint although this was more to do with using the can up than the exhaust needing paint.
Fitted my chrome servo bolt that I have had since last October :)
Fitted my stainless door plates that I got from Smiffys Bits in the post.
The old crusty ones. These were only two years old believe it or not.
Old vs new.
Nice new shiny bits in place.
Found and refitted the little black plastic end piece that fell off my doors outer weather strip.
Still got plenty left to do but you have got to save something for another day hehe
#157 samsfern
samsfern
  • 5,243 posts
Posted 11 July 2010 - 08:57 PM
washed it this morning, *melonsed* yet another exhaust clamp on the backlanes, lucky the rest of the exhaust system has skids on, looks like theyve taken a few hits though :)
Edited by samsernie, 11 July 2010 - 09:01 PM.
#158 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 11 July 2010 - 09:14 PM
Took my Studio 2 Decals off, along with my GB and Mini boot badges :)
#159 l_jonez
l_jonez
  • 1,453 posts
Posted 11 July 2010 - 09:54 PM
layed a load of dynamat fitted full interior, gave the bonnet a final flat and polish (altho it will get resprayed when i get chance) fitted headlights and loads of other little jobs that seem to take forever
#160 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 11 July 2010 - 11:08 PM
Destroyed my overdraft!
#161 wurzel555
wurzel555
  • 10 posts
  • Local Club: Subaru Impreza GT Club
Posted 13 July 2010 - 02:49 PM
Walked past it, jumped in my Impreza and drove to work :thumbsup:
#162 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 13 July 2010 - 02:51 PM
well attemped to fit my hilos but didnt go to plan did fit together lol
#163 minihurles
minihurles
  • 22 posts
  • Local Club: not at the moment
Posted 13 July 2010 - 03:16 PM
bougth a cheery bomb exhaust and my mate welded it on sounds good now
#164 mars red mike
mars red mike
  • 1,500 posts
I had one of those days today where you start a very simple job that should only take 20 mins max and ends up taking three hours. Started off by deciding to have a look at the top steering column bush as it had become displaced. Ended up replacing both steering column bushes, the indicator/wiper arms unit, and having the steering wheel on and off about eight times before it was straight. Plus it was raining. Not proper heavy rain but that boring cant be bothered to rain properly drizzle that soaks you right through.
I should have stayed indoors today.........
#165 Midas Mk1
Midas Mk1
  • 5,774 posts
Posted 13 July 2010 - 03:42 PM
Built up my rear subframe, then fitted it :thumbsup:
