#1531
Posted 11 March 2012 - 08:57 PM
#1532
Posted 11 March 2012 - 09:07 PM
Then I took some pics of rust for us to oooh and tut at. They are in my build thread.
Al
#1533
Posted 11 March 2012 - 09:13 PM
#1534
Posted 11 March 2012 - 10:59 PM
#1535
Posted 11 March 2012 - 11:00 PM
Have a little pock about ready to fit all new bushes front and back! Wish me luck dropping rear subframe. I hope i get lucky and not have to drag the welder out!
That reminds me, i've got my front bushes to do aswell, hope your rear subby comes out ok
#1536
Posted 11 March 2012 - 11:01 PM
#1537
Posted 11 March 2012 - 11:08 PM
#1538
Posted 11 March 2012 - 11:17 PM
i really need to sort it out..bring on the summer
#1539
Posted 11 March 2012 - 11:18 PM
Started bleeding my brakes armed with a spanner and a syringe, so far no real pedal and lots of ballache trying to do it solo
If your brake fluid hasn't been changed in a while your best to drain the whole lot. I think brake fluid should be changed at least every 2 years. Remember to top up the system as you go otherwise you will just drag more air into it
Get yourself an easy bleed, so much easier
I've got an easy bleed system which I used today, you can pick them up in Halfords for about a tenner. My proffered easy bleed is the Mrs. I normally get her to pump the pedal so I can be certain all the air is out.
#1540
Posted 11 March 2012 - 11:19 PM
If your brake fluid hasn't been changed in a while your best to drain the whole lot. I think brake fluid should be changed at least every 2 years. Remember to top up the system as you go otherwise you will just drag more air into itGet yourself an easy bleed, so much easier
May have to get one from halfords then as it was about £20 everywhere online and i didnt want to wait for delivery so thouht i would give it a go :)
#1541
Posted 11 March 2012 - 11:20 PM
#1542
Posted 11 March 2012 - 11:24 PM
#1543
Posted 11 March 2012 - 11:37 PM
The Mrs has always been my preferred method.
Down!........up!.............down!..............up!................down!...............up!..........down!...........up!........now down slowly........PUSH!!!
She's also good at helping me bleed the brakes
Al
#1544
Posted 11 March 2012 - 11:53 PM
Check this link out Alex. The gunson kits are good
http://www.halfords....||sor||Price||1
Thanks! Eezi bleed slightly more at halfrauds but i suppose its worth it getting it instantly :)
#1545
Posted 11 March 2012 - 11:59 PM
