Mini Starter Motor "clicking"
Posted 03 April 2010 - 01:12 PM
hi all- I've been trying to start my mini which hasn't run for a couple of years. Last week it was turning over fine but wouldn't run due to no spark! Then all of a sudden the starter wouldn't turn over and just clicks. I have tried moving the car in gear in case it was locked/jammed but still nothing!
I have replaced an engine earth cable too as the one was looking dodgy! Now though, the battery earth cable gets hot when I try to start it!
Could this just be a bad earth somewhere? And if so were are the usual places that need cleaning/replacing?
Any help is appreciated!
Any non-standard parts that might be involved with the problem?
Posted 03 April 2010 - 01:17 PM
hopes this helps
Posted 03 April 2010 - 04:47 PM
I tried cleaning all the contacts on the solenoid, and cleaned all connections on the starter itself- but still no luck! And I have put two new engine earth cables on.
Could the solenoid have broken/worn out through excessive use? It is defo the solenoid making the click noise because you can feel it if someone else tries to turn it over! Or is there a relay that links to the starter system that could be nakerd??
Posted 03 April 2010 - 05:14 PM
what style starter is it ? pre engaged ?
Posted 04 April 2010 - 12:54 AM
Posted 04 April 2010 - 07:33 AM
Posted 04 April 2010 - 09:58 AM
How do I "short" out the starter motor? It is an inertia motor too with one black cable going to it.
Thanks again everyone for your help!
Posted 04 April 2010 - 02:14 PM
hope this works
With the inertia starter, when you want to "short" it, you are not really working with the starter, you are jumpering the BIG terminals on the starter solenoid.
Put the car in neutral.
Turn the ignition switch on and set the choke.
Open the bonnet and find the starter solenoid.
Take an insulated handle screwdriver and use it to bridge the gap between the two large threaded posts on the solenoid. DO NOT let the scewdriver's metal blade touch ANYTHING else.
There WILL be sparks. If you are unprepared, the sparks might scare you into jumping back... causing you to trip, or bang your head on the bonnet. If there is enough power to spin the starter motor, it will spin.
Posted 05 April 2010 - 03:31 PM
I haven't had chance to recharge the battery yet as I need to use my dads battery charger (tomorrow).
Posted 05 April 2010 - 03:35 PM
Posted 05 April 2010 - 03:57 PM
Should the starter have turned over when it sparked?
You should not expect the starter motor to have turned over until you have charged the battery fully. You can get sparks even from a somewhat discharged battery. That said, I would have expected you to at least hear the motor try to turn the engine a bit... perhaps a clunk or grunt when you bridged the solenoid contacts.
Posted 05 April 2010 - 04:01 PM
Try a regular battery charger for several hours, not just a starting booster. If the battery is deeply discharged, all the power from the booster goes into the depleted battery, not towards starting the engine.
To go further than this, I couldn't even jump start my project mini after it's battery being REALLY discharged. (Two months in the cold).
And that was from my 307 diesel with plenty of beans being given to it.
As Mr Lawson says, the power was going straight into the empty battery. And don't think about taking this out of the circuit or you'll damage your alternator..
Get it on trickle charge.
