My Forced Induction Project
#91
Posted 23 May 2012 - 07:22 PM
Cheers,
Jon.
#92
Posted 24 May 2012 - 11:31 AM
#93
Posted 24 May 2012 - 08:46 PM
#94
Posted 24 May 2012 - 09:16 PM
Jon, only ran this setup with megajolt, best thing I ever bought...
That's good to know, I may have to seriously consider it... Where did you get the bits from? Did you source them yourself or buy it as a complete kit?
Cheers, Jon.
#95
Posted 25 May 2012 - 10:10 PM
#96
Posted 26 May 2012 - 07:25 PM
#97
Posted 26 May 2012 - 09:45 PM
#98
Posted 28 May 2012 - 08:56 AM
#99
Posted 28 May 2012 - 02:01 PM
#100
Posted 28 May 2012 - 03:55 PM
Mine runs with the standard distributor (it's an electric one being a 93 Mini) and I've never really had any problems with it. Only real problem is the rolling road disconnected the vacuum advance so the ignition timing doesn't change as the revs increase...
Unless your dizzy has been locked it will still advance regardless of whether the vac pipe is connected or not.
#101
Posted 28 May 2012 - 10:41 PM
Ah fair play, my mistake, I thought the vacuum line was to advance the ignition? Or does that simply advance it further? Cheers, Jon.
#102
Posted 28 May 2012 - 10:43 PM
I am running a standard dizzy at the moment which runs fine. Only problem i am having is the rough idle pick up if i am sat in traffic. But i still need to go for a rolling road session which may help sort that problem?
Yeah that sould help sort the problem, it could be down to a number of things, whether it has oil in the dashpot, timing, needle etc, a rolling road session will have it running at it's best... Providing they are any good of course haha.
#103
Posted 29 May 2012 - 10:34 AM
How hard is megajolt to fit?
#104
Posted 31 May 2012 - 09:03 AM
dizzy with the suck through . the vac advance stays on no matter what .. i put a vac peice off a dizzy on the vac line you can watch it and it does not move at all over all revs
vac advance waste of time with the suck through full stop
had problems with mine dieing when you went to stop . turned out to be thicker oil in the dash . and the advance of the dizzy down low was on the piss . megajolt is not fine
get your self a aem wide band afr gauge .. helps to get a rough idea
below is what mines at now .. ford coil pack . rubber insulated bracket onto starter motor . made to look similar to dizzy ( hate fire wall mounted coils )
need to get this beast back out . to good to be sitting
Edited by new_zealand _minis, 31 May 2012 - 09:12 AM.
#105
Posted 28 June 2012 - 02:07 PM
loving the monza fuel cap on the rocker cover
