Spanner Sizes
Posted 28 March 2010 - 09:18 PM
Having got my head around metric thread sizes = spanner size
ie M5 tread = 8mm spanner, mate tread = 13mm spanner.
I wondered it was the same with UNC (if thats correct for a mini)
Has someone got a link to spanner, tread, drill sizes?
I have to buy some taps and dies ( I own a mini!)
Mainly to retap rear subframe captive bolts, the ones on the stubby.
Thanks in advance,
John
Posted 28 March 2010 - 09:24 PM
Posted 28 March 2010 - 11:13 PM
Fastener diameter --- wrench (across flats)
1/4" --- 7/16"
5/16" --- 1/2"
3/8" --- 9/16"
1/2" --- 3/4"
For the taps and dies, as Mini_Mad said, most are UNF. There is a simple rule for finding the drill sizes needed but you have to know the threads-per-inch for this to work.
UNF Thread
1/4 x 28 threads/inch
5/16 x 24
3/8 x 24
1/2 x 20
To find the tap drill (for 75-80% thread), subtract 1/pitch from the major diameter of the fastener.
For example...
1/4 x 28 = 1/4" - 1/28 = .250" - .036 = .214"
You'll need to round that up or down as necessary to find the closest drill available.
Posted 29 March 2010 - 01:37 AM
tapchart.pdf (application/pdf Object)
I'm sure you can find summary lists online but I'll offer the following quick summary of common sizes.
1/4" --- 7/16"
5/16" --- 1/2"
3/8" --- 9/16"
1/2" --- 3/4"
UNF Thread
5/16 x 24
3/8 x 24
1/2 x 20
For example...
Posted 29 March 2010 - 02:37 AM
5/16" UNF is the most common thread for those cut in steel/iron on a mini and is that used on the rear subframe mounts.
