Ok, so radius arms are on and all finished so guys are now sorting brakes/handbrake - really pleased with the result. Spec as follows from Phil/Matt:
Standard frame with radius arms and cone/trumpets 29KG (the one weighed had no brake parts at all fitted no hubs, backplates, shoes or drums)
A bare KAD beam comes in at 6KG with no arms.
This pair of arms with mounting plates etc, but again no brakes or hubs so good comparison, come in at 9.2 KG for the pair.
Arms are 38mm diam. T45 steel with standard Metro Radius arm pins, which are a little larger and stronger and with roller bearings at both ends rather than 1 roller bearing and 1 bush at the other on a mini.
The arm unit has built in camber adjuster and castor will be done via shimming the bracket if necessary. The arms from pin centre to hub centre are 335mm long compared to a standard arm of 295mm so should have a slightly smoother action.
They attach to the car via 6 mounting points, 2 are the standard mini heel board mounts whilst the other 4 are held on via 8mm steel plate tapped to 5/16 unf thread, the plate is welded inside the heel board and triangulated to the cage.
The handbrake quadrant is a KAD part with the fulcrum point being in the centre of the 6mm triangular plate in the centre of the arm. They also have the larger KAD stub axles fitted.
Customish Protech shocks as per the front, again the lads there were first class, phoned one day, were on the car the next.
So there you go, I think the arms look great, I would push the boat out and even be willing to cause controversy by saying they look better than the force racing ones!... not quite such exotic materials but yet to sell a kidney. As you can imagine, huge amount of thought and design has gone into this, the keener eyed amongst you will no doubt see that a few design developments have come up as things have progressed but do think they've turned out well and Matt, Phil and the gang have done a sterling job.
All in all means car should be rolling again soon which, after 9 years is quite good news!
If you fancy some rad arms give Phil a ring, sure he'd be happy to make some more!
Edited by Alan Carruthers, 14 November 2012 - 07:51 PM.
