Mayfair2
#256
Posted 08 April 2015 - 07:54 PM
Al
#258
Posted 18 April 2015 - 03:49 PM
Also, does anyone know where I can get a bonnet like this, tried Zcars but no response:
http://www.zcarsuk.c...gory&path=61_65
A
#259
Posted 18 April 2015 - 03:52 PM
#260
Posted 18 April 2015 - 03:53 PM
I think ABS Motorsport sell one like that.
#261
Posted 20 April 2015 - 06:58 AM
looking stunning mate such an awesome build, but yeh bonnet wise ABS should be able to supply you one id say
#262
Posted 28 April 2015 - 06:46 AM
Scott
#263
Posted 04 May 2015 - 11:38 AM
#264
Posted 05 May 2015 - 09:40 AM
that is pure porn, build to perfection and now too good for the track
...and some nice ideas for my track tool too, I like the lotus pedal box a lot. Need to start to hunt for one too....
Where did you get that huge rear-view mirror?
#265
Posted 01 June 2015 - 09:16 PM
Also got the stance pretty much sorted with spacers and longer studs and that's made a world of difference. Unfortunately the front's almost as low as it will go as the wings were cut back a lot to suit the wheels and arches went on after that.
New column meant that stalks won't work sadly but has resulted in some pretty exciting new switch gear, also kept up the carbon addiction and got a few new bits through from Ben, quality as ever.
RP have also had to take the rear suspension apart entirely as radius arms were on the wrong sides! All sorted now though, like almost all the car it's been done twice or more but that's what happens when you try new things.
Paul's hopefully back up to finish off in the next couple of weeks so look out!
The overtaking mirror was made from scratch I'm afraid but relatively simple metal box and angled stiffeners, small sections of mirror then bonded to the stiffeners.
Take it easy,
Al
#266
Posted 28 July 2015 - 08:46 PM
Nearly there!
Bit more stance!
Seats back in
Loud bit all sorted, video later
Shifter connection beefed up
Managed to keep the bulkhead clean in the end
Tanks worked out really well, not so much suspension travel!
Force Racing maketh the Mini, matching grommets side to side worked well
Got some further updates on the way to really make use of the airbox
Back window needs a clean but rainlight is all finished
Spare in
Catch tank all done
#267
Posted 28 July 2015 - 08:56 PM
#268
Posted 28 July 2015 - 09:02 PM
And inside...
Wiring complete bar some interior lighting and power commander
Bulkhead all done
Bit carried away here, reservoirs and bracket painted
So this is a massive update, stalks weren't working out so switches now on the wheel, programming is really trick
Can see the Motogadget M-lock here, basically an imobiliser but with some fancy wiring it turns the ignition on
Need to work out what these all do!
Thanks for looking, hope you like it.
Al
#269
Posted 28 July 2015 - 09:32 PM
Cheers Duds, hope so, Cal is going to give it a first drive this week, fingers etc crossed.
So you know all about this noise mate... I didn't! 10 years and 11 months since I drove it but its turned out alright!
Suggest you use earphones and turn it up...
Al
#270
Posted 29 July 2015 - 07:01 AM
Dude it looks so so so good! I love what you`ve done with the interior especially, what a cockpit. Wiper motor in the inside is a nifty little trick too. How did you make your internal release for the door handles & are they still lockable? The arc-angles do a kit is it like that one? I need to do something just like that on mine.
What have you got planned for the air intake?
