Minimum Temperature For Spraying 2k?
Posted 25 March 2010 - 07:26 PM
Hope someone can help
Josh
Posted 25 March 2010 - 07:34 PM
that help?
Posted 25 March 2010 - 07:47 PM
Posted 25 March 2010 - 08:04 PM
Really the minimum temp you want is around 20 degrees but I have sprayed it in slightly lower temps, If you are spraying in a garage then you should be worrying more about breathing as it contains cyanide. If you do spray it then using express hardener is the best for in garages.Hi does anyone konw the minimum temperature for spraying 2k?
Josh
Posted 25 March 2010 - 08:09 PM
cheers
Posted 25 March 2010 - 10:22 PM
Posted 26 March 2010 - 11:10 AM
2 pack contains isocyanate, not cyanide. Isocyanate can cause hypersensitivity pneumonitis as well as asthma among other things. People have even been known to drop dead from inhaling too much with no prior exposure. It's nasty stuff.
Posted 26 March 2010 - 04:27 PM
cheers
josh
Posted 26 March 2010 - 06:41 PM
Posted 26 March 2010 - 06:56 PM
Josh
Posted 30 March 2010 - 12:28 PM
Hi Midridge,frog, thats one of the myths that people talk about but never bother checking, 2k does not contain cyanide. go check it out.
Yes that is correct it doesn't actually list contents as canide but it contains xylenes which are poisonous and attack your nervous sytems etc just like cyanide does. Either way you really don't want to be breathing it in.
