What 10w40 Oil Do You Use?
12 replies to this topic
#1 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 22 March 2010 - 09:45 AM
For those running 10W40 oil - what type are you using? The engine is a freshly rebuilt 1330, kent 276, big valve head etc.
#2 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 22 March 2010 - 10:00 AM
i think my valvoline is that grade, i cant remember but i got it from min-its
hmm...need an oil change anyway :(
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 March 2010 - 10:04 AM
I generally use Comma oil, as I buy it in BIG tubs...
But any brand mineral should be good for the job, eg the Halfords stuff which comes in the orange plastic bottles.
#4 Pooky
Pooky
  • 5,691 posts
Posted 22 March 2010 - 10:19 AM
I seem to be only able to find 10W40 in semi-synthetic eg. Halfords own brand and Mobil. Would this be ok?
Has the engine been run in Ouster?
#5 Ouster
Ouster
  • 2,986 posts
Posted 22 March 2010 - 10:28 AM
Nope, hasn't been run in yet. My engine builder (who clearly knows his stuff) said to use a good quality expensive oil and change it after 500 miles are so - which differs from the advice I've read on here!
I had a quick look in Halfords yesterday when buying some paint and noticed that all the 10w40 was semi synthetic too.
#6 mini93
mini93
  • 8,615 posts
Posted 22 March 2010 - 10:32 AM
just curious, whos built the engine?
coming to think about it, i think the valvoline stuff i used was semi sinth, you after just mineral oil?
#7 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 22 March 2010 - 10:34 AM
Use a branded oil and change it every 5-6 months or 5000-7000 miles.
Bel Ray oil is really really good.
#8 Ouster
Ouster
  • 2,986 posts
Posted 22 March 2010 - 10:35 AM
Mineral, semi-synth, anything that won't ruin my seals! If i can find mineral should I get that?
Roe engineering in Fleet, Hampshire built it. Proper old machine shop - no computers in there!
Edited by Ouster, 22 March 2010 - 10:36 AM.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 March 2010 - 10:36 AM
To run in, you need an oil which DOES NOT have the protective agents in it like most 'brand' engine oils do... You can buy specific running in engine oils, and I would change it after 50 miles not 500...
How you run an engine in is your preference, some moly coddle the engine for x thousand miles, some ( like me ) run it hard for 50 miles or so working on the principle that the rings are bedded in within a few minutes of the engine first starting, and a good 50 hard miles on the engine will have knokced all the corners off, if it aint broke by then it's unlikely to break.
#10 Ouster
Ouster
  • 2,986 posts
Posted 22 March 2010 - 10:38 AM
Asda and the like sell cheap oil don't they - would you run it in on something like that?
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 22 March 2010 - 10:40 AM
According to Halford specifications castrol GTX is mineral
http://www.halfords....tegoryId_165581
You'd need an extra 1 litre though thats only a 4 litre tub
#12 ohsuchislife
ohsuchislife
  • 200 posts
Posted 22 March 2010 - 10:49 AM
i usew the GTX .. bit of a con .. when you have to buy a extra 1ltr ...
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 March 2010 - 10:54 AM
Halfords 10/40 enhanced Mineral... 5l tub
