thanks your a stari have already repaired the heal section and i don't think any one makes just that plate ,i had a look unless you know any one ?all i have found is full heal or half heal or the corner repair section with the captive nuts which is not what i need, any help would be great again love the work....simonwow what a job from the metal work to the paint, hope mine come out half as good and ill be happy, can i ask for some help on how you made the subframe mounting point ie. how thick the steel is, ruff size ,it looks like you used two plates if so did you shape both or just the top one as much info as you can may be some picture ? or a drawing if you can this would be so much help again great work please please help!!!!!!!!!simon
Cheers, I used two pieces of 1mm steel, plug welded together. Admittedly not ideal, but I didn't have any thicker gauge stuff lying about. I shaped both plates. I would buy a proper mounting point if I were you, they're not expensive and it saves alot of hassle! I only did it that was as I had limited time and money.
yes mate, M-Machine make one. There is a short section of heelboard attached, but it's very easily removed.
Flo's Body Resto
#151
Posted 29 April 2010 - 10:50 PM
#152
Posted 29 April 2010 - 11:02 PM
Keep up the good work
#153
Posted 30 April 2010 - 06:27 PM
Did you wet on wet the car before you based it or did u base over the top of the original base?
#154
Posted 30 April 2010 - 08:27 PM
#155
Posted 01 May 2010 - 05:05 PM
#156
Posted 01 May 2010 - 06:32 PM
#157
Posted 02 May 2010 - 06:56 AM
Cheers Ross.
#158
Posted 02 May 2010 - 08:03 AM
#159
Posted 02 May 2010 - 09:15 AM
#160
Posted 02 May 2010 - 02:53 PM
Going from cherry red to smoke grey!
LUV YOU
#161
Posted 03 May 2010 - 04:47 PM
#162
Posted 03 May 2010 - 07:37 PM
#163
Posted 03 May 2010 - 08:00 PM
#164
Posted 03 May 2010 - 08:18 PM
i fear i may have hijacked petes topic...
sorry
Haha no probs.. so long as you apply enough paint, nothing will bleed through, unless you;re putting white over red, which will always go pink. It;s always best to prime and flat the whole car, but sometimes time is a limiting factor, and if you're spraying the car the same or very nearly the same colour and the paint is in good condition, the need to prime over it pretty much goes out of the window.
#165
Posted 03 May 2010 - 08:21 PM
Pictures yet?!
Sorry
