How To Change Engine Mounts! Really Cant Be That Hard To Find!
Posted 20 March 2010 - 12:42 PM
1993 rio!(yuck) stage one lcb etc!
Posted 20 March 2010 - 12:59 PM
Engine mounts are a bit of a fiddle and will require the removal of one side at a time ( suggest doing the o/s first ). You will need to support the engine and remove the clutch cover (wok) and then you can replace the engine mount which is attached to it... The n/s you will again need to support the engine and then remove the radiator, and after that the radiator bracket, you can then access the engine mount which is attached to that.
Posted 20 March 2010 - 01:20 PM
It's more likely to be your top engine steady bushes ( or the bracket ) which have failed... Was the exhaust strapped to the back of the gearbox, if not that will also cause stresses on the pipe.
blimey charlie you guys dont mess about that was fast!! okay so what/where do i find this bracket is it expensive or safe to drive before i get the parts? this clutch cover(wok) does it look like a wok then? lol! we talking a day week to do or hour?
Posted 20 March 2010 - 01:42 PM
Posted 20 March 2010 - 02:37 PM
Edited by L400RAS, 20 March 2010 - 02:38 PM.
Posted 20 March 2010 - 03:44 PM
These pictures should help. The upper steady bar that guessworks refers to is on the left hand side as you look at hte engine, above hte flywheel housing wok. Put the handbrake on hard, and then wobble the engine forwards and back, checking for movement in the bar / bushes. If movement here, replace the bushes. Availaible from minispares.com etc very cheap, you could even look at poly bushes.
Thats great just going to have a brew and then attempt to have a go!! would you reccomend poly bushes? also where did you get such detailed drawings? is that a haynes book scanned in to your puter!!
Posted 20 March 2010 - 04:03 PM
I poly bush mine, you do get slight increase in noise, but they are much harder and hold the engine more, however - when they fail their perforemance decreases much quicker than the standard rubber ones if you get me.would you reccomend poly bushes? also where did you get such detailed drawings? is that a haynes book scanned in to your puter!!
Regarding the drawings, these are not haynes...
PM me your email address if you wish me to send you a load of pdfs...
Ryan
Posted 20 March 2010 - 04:14 PM
Ryan
does this offer stand for anyone?
Posted 20 March 2010 - 04:17 PM
i had this with mine fairly recently, the top engine steady had snapped the bracket on the bulkhead which i had to weld back on
Ryan
Until i get bored of sending loads of emails...
Posted 20 March 2010 - 05:09 PM
Posted 20 March 2010 - 07:01 PM
