Engine Knocking
9 replies to this topic
#1 tootgarook
tootgarook
    Just On Tickover
  • 6 posts
Posted 19 March 2010 - 07:54 AM
engine knocking sound recently developed, car starts well, no lack of power, and not blowing any smoke.
sound appears to be from top of engine/head.
have noticed some water droplets collecting in rocker cover cap. no water on main engine .
mini 1964 850cc.
have taken car to x 2 garages, one said "blown piston " the other said " big end gone".
I was wondering could it be tappets ?
Any advice would be much appreciated.
thanks
#2 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 19 March 2010 - 08:18 AM
I'd check the tappets first but the tend to rattle not knock though. check the cylinder compressions when the engine is hot. If these are all OK then it is either a littl end or detonation. Detonation is when the ignition is too advanced usually with a weaker than normal mixture.
#3 MRA
MRA
  • 7,607 posts
Posted 19 March 2010 - 09:01 AM
does it still knock when under load ? if so then its probably not big ends
#4 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 19 March 2010 - 09:41 AM
mini 1964 850cc.
A blown piston, does the engine only run on 3 cylinders. Big end gone, that would generally be a thud from the bottom end rather than a knocking.
As said tappets would be a rattle rather than a knock. I think a cylinder leakage test is in order, it sounds like the head gasket to me.
thanks
#5 tootgarook
tootgarook
    Just On Tickover
  • 6 posts
Posted 19 March 2010 - 10:08 AM
if i drive up hill and don't change down gear and make the engine struggle , the knocking disappears. the higher the rev the worse it gets. if i drive really conservatively at low rev can aviod knocking noise !
#6 MRA
MRA
  • 7,607 posts
Posted 19 March 2010 - 11:12 AM
that sounds like big ends to me :thumbsup:
A head gasket would get worse under load..... tappets would just rattle more with the increase in engine revs
#7 nomininolife
nomininolife
  • 982 posts
Posted 19 March 2010 - 11:18 AM
He does say it gets worse under load
David
#8 MRA
MRA
  • 7,607 posts
Posted 19 March 2010 - 12:45 PM
Does he ? I must have missed that :thumbsup:
However I did see this :P
#9 tootgarook
tootgarook
    Just On Tickover
  • 6 posts
Posted 19 March 2010 - 10:54 PM
thanks for advice.
think I will buy a compression test kit to start with, unfortunately local garages here are
reluctant to mend mini's, so it's down to me with limited knowledge +book.
Have just bought complete 1000cc engine off ebay which is mean't to go, worst case it might be good for parts !
#10 tootgarook
tootgarook
    Just On Tickover
  • 6 posts
Posted 24 March 2010 - 05:18 AM
850cc engine, just completed compression test ,ranging from 95 - 100psi dry, with oil in cylinders went up to 120psi. !!!
Knocking appears to be getting worse from inside engine.
Have a complete secondhand 1000cc engine being delivered Saturday, is a change over
that difficult ? never done one before.
any advice would be great.
thanks
