Imperial Bolts And Metric Tools?
Posted 17 March 2010 - 08:47 AM
Posted 17 March 2010 - 08:54 AM
Would rather buy another set than ruin anything!!
Posted 17 March 2010 - 08:59 AM
Bear in mind not everything is imperial on a Mini and it various according to which Mini you have!
Edited by Pooky, 17 March 2010 - 09:00 AM.
Posted 17 March 2010 - 09:20 AM
7/16" AF
1/2" AF
9/16" AF
5/8" AF
Definitly those 4, get combination spanners ring and open ended
Edited by lrostoke, 17 March 2010 - 09:21 AM.
Posted 17 March 2010 - 09:23 AM
Although some metrics are pretty close and I do use both, I recommend getting some imperial spanners.
7/16" AF
1/2" AF
9/16" AF
5/8" AF
Thanks probably best off just getting a few that are needed to rather than whole set!!
Would sockets be better? so can use torque wrenches?
Edited by bunch1980, 17 March 2010 - 09:27 AM.
Posted 17 March 2010 - 09:34 AM
I think Halfords have half price at the moment on their Professional range. Good stuff
Posted 17 March 2010 - 09:43 AM
Posted 17 March 2010 - 09:46 AM
As I said if you're going to own a Mini and work on it yourself you need the right tools. The four that lrostoke has said are the most common but they aren't the only ones! Also a socket set or spanner set alone won't get you far either. If you've got a 1/2" nut and bolt to undo you'll need the spanner on the bolt and the socket on the nut.
Very true, thanks for your advice.
Posted 17 March 2010 - 09:48 AM
The are the most common used around the engine.
When you come to suspension you're going to need 5/8, 11/16 and bigger...
Personally, as a starter kit I would buy a cheap set ( YES Cheap set ) of combination spanners from 3/8" all the way upto 1"
eg. http://www.machinema...anners-wrenches
and then invest in a decent set of ratchet spanners
eg. http://www.halfords....tegoryId_165572
and then couple that with a set of AF deep sockets ( 3/8" drive is my preference ), extension bars and ratchet.
Then as you have funds available, or the cheap spanners break, replace them one at a time with better quality items..
Rule being, cheap spanners which are the right size are better than expensive ones which aren't
Edited by Guess-Works.com, 17 March 2010 - 09:49 AM.
Posted 17 March 2010 - 09:55 AM
7/16" AF
1/2" AF
9/16" AF
5/8" AF
At the end you need 4 sockets, 4 spanners, a torque wrench, afiller gauge, a balljoint splitter and a cone compressor. You dont need a complete professional set and the use of metric spanners on old tight bolts/nuts is good only if you want some extra rounded bolts on your mini.. The only metric i use is 13mm for manifold nuts because its my only socket that fits there.. Usually cheap tools wont last long and arent very precise..
Extra tools you could need for some serious jobs are flywheel puller, clutch seal tool, a DTI, several pry bars and a hub puller..
Edited by jaydee, 17 March 2010 - 09:56 AM.
Posted 17 March 2010 - 10:24 AM
Most are universal and work equally well in metric and imperial applications
Another must have is the proper square hole brake adjusting spanner.
Posted 17 March 2010 - 01:12 PM
Bear in mind not everything is imperial on a Mini and it various according to which Mini you have!.
Can you give some guidance where A/F may have changed to metric. Or are all minis a mix. I have a 93 Cooper. Will that be all metric ??
Posted 17 March 2010 - 01:51 PM
Posted 17 March 2010 - 01:53 PM
