Seat Adjuster Brackets
#16
Posted 17 March 2010 - 02:31 PM
Ben
#17
Posted 17 March 2010 - 02:50 PM
the problem lies with the seat now being too far back for the little hook underneath to go under the hook on the floor
it never bothered me as i wear a seat belt, im sure that will hold the seat down enough
i drilled another hole through in mine to hold it down better too
#18
Posted 17 March 2010 - 03:36 PM
#19
Posted 17 March 2010 - 03:41 PM
#20
Posted 17 March 2010 - 04:08 PM
this may be cheeky but could someone meausure me some of the brackets and that way i can make some cheers sorry if that is cheeky
its not cheeky, you dont have to make them exact to what they sell as, it would be better to make them to suit your own standard
#21
Posted 17 March 2010 - 04:30 PM
Perhaps you can bend it back enough to catch.
#22
Posted 17 March 2010 - 05:15 PM
#23
Posted 17 March 2010 - 06:10 PM
The hold down catch is supposed to stop your seat flying forwards in the event of any sort of accident and thus would stop your brains from either going through the roof of your car or being splattered and sent through your windscreen, hence why its required for an MOT.
I most certianly would not -
a) leave it and swap the brackets for MOT time (unless you like driving around in fear?)
or
b) bend any safety critical brackets in any car, let alone a mini.
Moving the seat forward one notch on the seat adjuster (im sure thats all its going to take) and making sure the hold down catch does indeed catch the bar thats welded to the floor is the safest thing to do here.
Safety > Comfort , thats the order people should work in!!
Edited by silva_mini, 17 March 2010 - 06:42 PM.
#24
Posted 17 March 2010 - 06:24 PM
#25
Posted 17 March 2010 - 06:40 PM
If you go to this extreme to move it further back then you do realise no one will be able to sit in the back??
If your not having rear seat access why not get some fixed back (non tilt) seats and make a subframe for them that can bolt through the floor instead of using the catch??
#26
Posted 17 March 2010 - 06:50 PM
#27
Posted 17 March 2010 - 06:54 PM
#28
Posted 25 March 2010 - 02:39 PM
Hmmm, sounds like some rather dangerous advice being given out here.
or
No 'dangerous" advise given by me.
The catch isn't designed to hold the weight of the seat AND a passenger. It is designed, as said, so the seat itself doesn't flip forward under hard breaking....not the seat and passenger....thats what the seat belt is for! If only an inch or so is needed...there's nothing wrong with making two slight bends so the hook is still catching the bar. The only force it is intended to withstand is the weight of the seat by itself trying to flip forward.....which, given the angle etc., isn't great, even under heavy braking.
I doubt your MOT over there would pass a car that has had the bracket "adapted" by welding etc, but if two neatly done bends are done....so the hook is still 90degrees to the bracket, I can't see that being an issue....safety or otherwise
#29
Posted 14 June 2018 - 04:29 PM
or
I thought mine was welded in. In that case you could do the above, but whatever you do, dont leave the seat un-catched at the back!
Heaven help those of us driving older models which didn't have the hooks fitted at all.
