I'm in the middle of doing the same job. I just finished the left one, which was difficult enough. I pulled down the reinforcing rubber piece and cut the hose off next to the fitting on the subframe. I got onto that with an 18mm deep socket. I chopped the brake pipe through with a chisel as I will be replacing it. I then put all my 1/2" drive extensions together and just got onto the big 15/16" nut with a socket. I went down the front face of the rad, with the ratchet sticking out above the wing. It was real tight but I got it undone. I cleaned the nut up to reuse, but then found the QH replacement hoses include a nut.
Now I'm asking the same question - the right hand one does not have direct access from above - and access from the front looks difficult.
I'm thinking I could remove the clutch release lever, and maybe undo the engine mount and jiggle the engine forward a little (maybe just taking the lever off would be enough) and then I can get access to the banjo bolt and the big nut from directly above like I did the other side.
Am I doing it right or is there an easier way.. A trick I'm missing perhaps?
Mart.
PS a little more info for anyone doing the job- the spanner size for the end of the pipe into the wheel cylinder (my car has drums) is 15mm, and when you are fitting the pipe, you should fit the wheel cylinder end first, then the chassis end making sure there is no wind up in the hose. I'll get the size of the banjo bolt tomorrow when I have another look at the job.
M.
Edited by 82hle, 09 April 2010 - 11:36 PM.
