Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#121 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 01:39 PM
So, brand new subframe. I know it's a pattern one, it's all I had access to. I will reinforce it and repaint it later.
#122 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 01:40 PM
These brackets I had for a long time on a shelf and I finally put them on
#123 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 01:42 PM
Now the rear valance. I filled these holes as I won't use them, and I also filled the the small cutout for the exhaust.
Edited by dasupersprint, 04 October 2016 - 02:51 PM.
#124 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 01:44 PM
#125 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 01:51 PM
Also put these plates on, I guess they are lifting points?
#126 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 02:22 PM
Valance closing panel
Fitting:
I disassembled it a bit, to make it fit better:
Fit:
Weld:
And the final piece:
#127 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 02:31 PM
Other side
#128 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 02:33 PM
Inside reinforcing
#129 dasupersprint
dasupersprint
  • 848 posts
Posted 04 October 2016 - 02:38 PM
The outer sills. I KNOW they are oversills, and that they are evil. But that's what I have. I cut them to make proper sills
Cut line
First try to fit, not too bad
Edited by dasupersprint, 04 October 2016 - 02:45 PM.
#130 MacGyver
MacGyver
  • 1,027 posts
Posted 04 October 2016 - 06:48 PM
Nice progress! 😎
Love it when bits go back on.
By the way the little plates in the floor corners are not lifting plates, they where for attaching the shell in the factory for building it or something, don't try to lift it by those points as it will just bend...
#131 dasupersprint
dasupersprint
  • 848 posts
Posted 05 October 2016 - 12:06 PM
Nice progress!
Thanks for the info!
#132 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2016 - 02:53 PM
More fitting. I had to move the hole for the lifting point as it was about 1cm off.
And done for both sides. Look so much more finished
#133 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2016 - 02:55 PM
Found an easy way to move the shell around
#134 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2016 - 03:01 PM
Then I wanted to install the brackets related to the fuel tanks. For that, I had to try fit the fuel tanks. And for that, the spit was in the way! So I partially got the spit off at the back to do all this.
I came with this way to hold the shell:
I could then fit these
We see that I also put in the brackets to hold some some a a boot board near the back panel
#135 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2016 - 03:02 PM
For whatever reason I forgot to buy the other brackets that hold a boot board, those going behind the seat back. So I made my own.
