Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#91 dasupersprint
dasupersprint
  • 848 posts
Posted 04 August 2015 - 11:52 AM
Now I had to replace the brackets that the rear subframe bolt into. They are at both ends of the heelboard. Since that part seemed really difficult to have new, I didn't have much choice but to make them.
I mesured the bolt patterns from the subframe, marked the heelboard and drilled holes in it first.
Then I could drill the same holes in the bracket, and weld in a reinforcement
Then, weld in the nuts
Final product...
And in place
Edited by dasupersprint, 18 October 2019 - 03:43 PM.
#92 dasupersprint
dasupersprint
  • 848 posts
Posted 04 August 2015 - 11:55 AM
New boot floor
Old boot floor...
Edited by dasupersprint, 18 October 2019 - 03:46 PM.
#93 dasupersprint
dasupersprint
  • 848 posts
Posted 04 August 2015 - 11:59 AM
I began to cut the old boot floor
I I know I will have lots of little patches to take care of in the wheel arches
Edited by dasupersprint, 18 October 2019 - 03:47 PM.
#94 dasupersprint
dasupersprint
  • 848 posts
Posted 04 August 2015 - 12:03 PM
First, a big cut and repair in the left side arch along the white line
Cut
Old piece of rust
New piece of metal
I couldn't do it in one piece, so it's going in three
Edited by dasupersprint, 18 October 2019 - 03:52 PM.
#95 30 mm
30 mm
  • 181 posts
Posted 04 September 2015 - 06:54 AM
Great to see you back to work!!!
30
#96 Brams96
Brams96
  • 2,308 posts
Posted 04 September 2015 - 06:05 PM
Excellent photos explaining things & great work, keep at it ;)
#97 dasupersprint
dasupersprint
  • 848 posts
Posted 24 September 2015 - 12:51 PM
30
Thanks! I'm really happy to be back at it.
thanks! I really enjoy reading resto threads that are detailed, so I try as much as I can to make one myself
There is a bit more work done now. The left rear wing is sorted out, and a bit of the right one. Pictures coming in the next weeks. While it's still warm outside, I prefer to spend the time in the garage instead of in front of the computer!
#98 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:37 PM
A second piece for the inner left rear arch
Closed this with a correct panel
Done
From inside
Edited by dasupersprint, 18 October 2019 - 04:55 PM.
#99 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:40 PM
Now this area was again full of bad patches
But I have a panel for it!
Couldn't have the other side, so I made one myself.
Edited by dasupersprint, 18 October 2019 - 04:58 PM.
#100 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:41 PM
Edited by dasupersprint, 18 October 2019 - 05:00 PM.
#101 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:44 PM
Now the right side inner rear wing
Cut
This is bad. Will need replacing.
More cutting
Even more cutting...
Finally, new material
Edited by dasupersprint, 18 October 2019 - 05:04 PM.
#102 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:48 PM
Now repairing that reinforcement bracket.
New nut and bolt
Made that bracket from scratch
And in place it is
Edited by dasupersprint, 18 October 2019 - 05:08 PM.
#103 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:50 PM
Now, the corner is as bad as the other side was
Self-made panel
And this one
Edited by dasupersprint, 18 October 2019 - 05:11 PM.
#104 dasupersprint
dasupersprint
  • 848 posts
Posted 17 November 2015 - 05:53 PM
I had to repair the rear bins, as I cut them when I took the whole floor out.
Edited by dasupersprint, 18 October 2019 - 05:13 PM.
#105 dasupersprint
dasupersprint
  • 848 posts
Posted 19 May 2016 - 12:45 AM
Hello, 2016! Pics incoming.
    Bing (2)
