And it's sadly time to say goodbye to the beautiful red paint under the bonnet.
Posted 08 March 2021 - 02:30 PM
Posted 08 March 2021 - 02:31 PM
This material is Hoodliner by Dynamat
Posted 08 March 2021 - 02:33 PM
I bought last year the aluminium door handle kit, but as I have the earlier type horizontal pull handle, the new one was too long, as it's meant for the later diagonal type. So I made my own little design starting with a aluminium flat bar.
Posted 08 March 2021 - 02:34 PM
Here is a comparison between the original plastic handle, the new one from the kit and mine
Posted 08 March 2021 - 02:35 PM
I don't think it looks too bad
Posted 08 March 2021 - 02:45 PM
I'd be interested to know if you notice any decrease in sound level from this? I'm considering something similar.
Posted 08 March 2021 - 04:33 PM
I will tell once I get the car out in April
Posted 22 April 2021 - 04:14 PM
So I got the Mini out when it was warmer. I did the timing and carb adjustements and it went well. It even did a 250km run the next day without problem.
On another small shopping errand, a sizeable steel beam appeared on the middle of the road, from under the traffic and I couldn't avoid it and it hit hard on the sump... I got back home ASAP and got the Mini on jack stands to inspect the damages...
First thing, it could have been so much worse. It could have teared the brake like, fuel line, gearshift mechanism but only the sump was hit, the exhaust muffler and a couple of scratches under the floor. The exhaust shifted back 2cm.
I ordered a sump guard and will install as soon as I get it. It might not be able to take another hit like that...
Posted 22 April 2021 - 04:39 PM
Ouch! that was lucky that more damage wasn't caused.
Posted 22 April 2021 - 08:37 PM
Ouch, not nice...
But on the plus side, it seems you only got the cooling ribs broken and not the casing itself...
I know aluminium can also be welded, would it be a job to be done during the next oil change maxbe?
(thinking of getting a sumpguard once the engine will be one day in the car...)
Anyway, great thing that you could manage your to-do list during the winter and drive it again!
Posted 22 April 2021 - 08:51 PM
Was there a noticeable diffence in the noise level from the bonnet soundproofing?
Posted 23 April 2021 - 12:53 PM
Yes it is noticeably quieter, I now hear more of the tires rolling on the road, that must mean that I hear less of the engine. At 85kmh+ it's still a noisy car though
Edited by dasupersprint, 23 April 2021 - 12:53 PM.
Posted 03 May 2021 - 12:45 PM
So here is the newly found protection. I found it on ebay, is expensive and weights nothing. Now the car sits even lower but it's for a good cause.
Posted 03 May 2021 - 01:48 PM
Looks great!
Did you have to drill the holes in the subframe to mount the sump guard?
Now you finally have a badge on the front of the car, albeit not on the bonnet ;)
