Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#691 dasupersprint
dasupersprint
  • 848 posts
Posted 09 February 2021 - 09:11 PM
Though I was pretty stupid first time I pushed the seal in place, and broke it. Knowing myself, I bought not one but three of them. So I had to take this one out too with more screws
Edited by dasupersprint, 09 February 2021 - 09:11 PM.
#692 dasupersprint
dasupersprint
  • 848 posts
Posted 09 February 2021 - 09:13 PM
So second time I put packing tape over the gear spline that went over the bigger diameter so it made a little ramp for the seal to go over. Plus by using the tool properly and a little bit of vaseline it went perfect
Edited by dasupersprint, 09 February 2021 - 09:14 PM.
#693 pete l
pete l
  • 1,368 posts
Posted 10 February 2021 - 01:44 PM
Hi, do you have a link to where you bought your flywheel puller ?
I can't find a decent one on amazon !
Pete.
#694 dasupersprint
dasupersprint
  • 848 posts
Posted 10 February 2021 - 01:48 PM
Pete.
It's the Minispares one!
#695 pete l
pete l
  • 1,368 posts
Posted 10 February 2021 - 01:50 PM
oh, OK, thanks for the quick reply.
I missread your post, thinking you got it from amazon, sorry :-)
Edited by pete l, 10 February 2021 - 01:52 PM.
#696 dasupersprint
dasupersprint
  • 848 posts
Posted 10 February 2021 - 01:54 PM
I installed the new improved starter motor. This is what the holes look like after some filing to fit. I transferred all the wires onto the new solenoid, except the wires for the spot lights that will need more length to them.
#697 MiniMadRacer
MiniMadRacer
  • 886 posts
Posted 10 February 2021 - 02:06 PM
I soak my primary gear oil seals in engine oil before fitting, and push them in about 1.5 mm to make sure the clutch doesnt chew them up
#698 Project_Green
Project_Green
  • 24 posts
Posted 10 February 2021 - 05:21 PM
I did a 2 hours drive yesterday! Having time for myself is a rare thing so I went for a long drive. The clutch is still slipping but if I'm careful with the throttle it's good.
 You’ve done an amazing job, what mirrors are they ?
#699 dasupersprint
dasupersprint
  • 848 posts
Posted 10 February 2021 - 06:45 PM
The mirrors are the Minispares GAM215A and GAM216A, I needed the chrome base plates CZH3521 to raise them a little.
#700 dasupersprint
dasupersprint
  • 848 posts
Posted 15 February 2021 - 08:18 PM
When I tried to start the engine, It would die after a few seconds. I put the old solenoid and starter and it worked. I got the Mini outside in the cold to turn it around and move it in a corner of the garage. The new clutch was super grabby, so an adjustment may be needed. I had to make space for a new project that will eventually live outside when summer comes. The garage still belongs to the Mini :)
Edited by dasupersprint, 18 February 2021 - 01:53 PM.
#701 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 16 February 2021 - 08:04 AM
Oh ! Another Mini but from Italia? Nice :)
#702 dasupersprint
dasupersprint
  • 848 posts
Posted 16 February 2021 - 02:24 PM
Since she now knows what it's like to live with a small, slow and old car from across the ocean, my wife REALLY wanted a Fiat for herself. Of course I couldn't say no because I like everything about old cars and I will gladly take care of it. This one is not a restoration project, it's solid and working, so it's just a matter of bringing it to our taste and take good care of it. I will not detail everything about it here because this is the Mini forum, but it will be in the background!
#703 dasupersprint
dasupersprint
  • 848 posts
Posted 23 February 2021 - 02:43 PM
I had more sound insulation to install on top of the bitumen material. This time it's 8mm closed cell foam. I put it under the dashboard cards
Edited by dasupersprint, 23 February 2021 - 02:45 PM.
#704 dasupersprint
dasupersprint
  • 848 posts
Posted 23 February 2021 - 02:45 PM
And on all the firewall. (didn't bother to take a picture under the heater box, but it's there) I still have a lot of remaining material, so I will probably add more elsewhere later.
#705 dasupersprint
dasupersprint
  • 848 posts
Posted 08 March 2021 - 02:25 PM
Continuing my quest against noise, I put more foam material over the exhaust tunnel and heelboard
