Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#676 dasupersprint
dasupersprint
  • 848 posts
Posted 17 December 2020 - 06:17 PM
My main to-do list in picture:
- Rear camber brackets
- Starter motor
- Clutch
- Electronic ignition
#677 dasupersprint
dasupersprint
  • 848 posts
Posted 17 December 2020 - 06:18 PM
But first things first, a cute little filter on the valve cover
#678 colinf1
colinf1
  • 1,013 posts
Posted 17 December 2020 - 07:30 PM
I like your noodle protectors!
#679 dasupersprint
dasupersprint
  • 848 posts
Posted 08 January 2021 - 06:06 PM
They are essential with a narrow garage and kids that like to play in the Mini!
#680 dasupersprint
dasupersprint
  • 848 posts
Posted 08 January 2021 - 06:08 PM
So the clutch job:
The Haynes manual told to remove the radiator bracket to tilt the engine, but I decided to go further and to remove the rad completely, leaving the shroud. And by removing all engine steadies I was able to tilt it quite a bit.
#681 dasupersprint
dasupersprint
  • 848 posts
Posted 08 January 2021 - 06:09 PM
So access to the bottom bolts of the cover was not easy, but not impossible:
#682 dasupersprint
dasupersprint
  • 848 posts
Posted 08 January 2021 - 06:10 PM
And first important part off:
#683 dasupersprint
dasupersprint
  • 848 posts
Posted 08 January 2021 - 06:11 PM
When undoing the very bottom bolt of the flywheel cover, it was soaking wet with oil. And there is indeed oil at the bottom of the cover. Not a good sign
#684 dasupersprint
dasupersprint
  • 848 posts
Posted 04 February 2021 - 06:58 PM
I quickly made this tool to hold the ring gear in place. As I'm working alone, it's really handy. I stole the idea from a Facebook Mini page
#685 dasupersprint
dasupersprint
  • 848 posts
Posted 04 February 2021 - 07:03 PM
This bolt was a pain to remove! I had it by heating it and prying it with a 4 feet pole. Plus I had to buy the 1 1/2'' box socket just for it.
#686 dasupersprint
dasupersprint
  • 848 posts
Posted 04 February 2021 - 07:06 PM
I tried to save a little money by buying a general flywheel puller from Amazon. It had the right 3/8 UNF bolts, but the diameter of the puller itself was too small! Same thing with another one from a hardware store. So I returned them both, bought the real deal from Minispares and waited...
It came at the right time, because I have to speed up my winter jobs because I have to move the Mini to make space for something else that's coming soon, and was unexpected.
Edited by dasupersprint, 04 February 2021 - 07:07 PM.
#687 dasupersprint
dasupersprint
  • 848 posts
Posted 04 February 2021 - 07:09 PM
I was lucky to have the 15/16'' socket for this one. I came off quite easily, really easier than the previous bolt.
#688 dasupersprint
dasupersprint
  • 848 posts
Posted 09 February 2021 - 09:07 PM
So that's the supposedly failing seal. Let's hope it's really the problem
#689 dasupersprint
dasupersprint
  • 848 posts
Posted 09 February 2021 - 09:08 PM
I took it out with the wood screws solution... not easy to drill tiny holes in that tiny space. The primary gear came with it
#690 dasupersprint
dasupersprint
  • 848 posts
Posted 09 February 2021 - 09:10 PM
I needed the tool to push the new seal in place and I found this lovely thread here that gave away a 3d model of the tool. I had it printed by a friend and look at that:
https://www.theminif...d-printer-file/
Edited by dasupersprint, 09 February 2021 - 09:12 PM.
