Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#616 dasupersprint
dasupersprint
  • 848 posts
Posted 28 May 2020 - 04:33 PM
I received my boxes of noise insulation material, so begins my quest against noise.
First impression, that stuff is heavy! Each box is 26 pounds, or 12 kilos. I have two boxes of 36 square feet.
#617 dasupersprint
dasupersprint
  • 848 posts
Posted 28 May 2020 - 04:37 PM
I will work my way from back to front, because the most annoying for me is that exhaust drone.
I started with the boot floor and the boot lid. I did not do the seat back because I will do it from inside. I did everything I could without removing the fuel tanks. I'll keep extra material if one day I remove the tanks.
I did one test drive and it was already noticeably quieter, so my expectations are high for what's next!
#618 pete l
pete l
  • 1,537 posts
Posted 29 May 2020 - 08:40 AM
I personally think you are way overboard with this stuff. This bitumen based stuff is not sound proofing, it is panel deadening.
You do not need to add it to the whole panel.
What you need is MLV
https://hushcitysp.c...ed-vinyl-mlv-2/
#619 dasupersprint
dasupersprint
  • 848 posts
Posted 29 May 2020 - 05:59 PM
Well, I've been recommended this stuff by local Mini friends, and customers comments. Anyways, I got the stuff so I'll install it. I'm doing one section at a time with a good test drive between each of them to see the difference.
I'll keep the MLV in mind if I need even more quietness, thanks!
#620 dasupersprint
dasupersprint
  • 848 posts
Posted 01 June 2020 - 05:06 PM
Meanwhile...
Test drive confirms the exhaust is a lot less noisy. Now I hear the engine too much
#621 dasupersprint
dasupersprint
  • 848 posts
Posted 01 June 2020 - 05:11 PM
I already had lots of rock chips on the rear arches, so to prevent the complete loss of the paint I cut and applied a plastic film protection. I hope it will be ok you can barely tell it's there
#622 dasupersprint
dasupersprint
  • 848 posts
Posted 01 June 2020 - 05:14 PM
And I changed the gearlever for one that a local friend gave me. Mine had the plastic ball damaged and that's why I had so much trouble getting it into reverse gear. The ''new'' one is from a Moke, so it has lots a weird curvatures but it works.
#623 dasupersprint
dasupersprint
  • 848 posts
Posted 10 June 2020 - 05:10 PM
I'm putting the isolation aside because I received the Stage 1 kit. It's a side exit RC40 standard bore, double box.
#624 dasupersprint
dasupersprint
  • 848 posts
Posted 10 June 2020 - 05:11 PM
The only disappointing thing is that the tip of the backbox was damaged during transport. I can't really do anything about it.
Edited by dasupersprint, 10 June 2020 - 05:11 PM.
#625 dasupersprint
dasupersprint
  • 848 posts
Posted 10 June 2020 - 05:13 PM
I painted the manifold so it lasts longer. I chose white, so it can look at bit like a Ferrari 312 F1 car?!
#626 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 10 June 2020 - 06:03 PM
+1 for the Stage 1, that will transform your car!!
-1 for the chrome, I bet it's on the top side? But as the chrom is flaking, that seems to be a problem by coating more than transport?
#627 timmy850
timmy850
  • 3,605 posts
  • Local Club: MITG
Posted 11 June 2020 - 10:11 AM
Mine has the same ding on the tip from transit... I was able to knock it back a very little bit with a hammer
#628 dasupersprint
dasupersprint
  • 848 posts
Posted 11 June 2020 - 05:01 PM
So here's that nicely white manifold in place
#629 dasupersprint
dasupersprint
  • 848 posts
Posted 11 June 2020 - 05:03 PM
Oh, and those welds don't clear the washers at all, had to improvise. Probably all of us who installed this went through the same
#630 dasupersprint
dasupersprint
  • 848 posts
Posted 11 June 2020 - 05:05 PM
While I had the gaping dash hole accessible, I found a way to reduce engine noise (I hope). It's piece of masonite backed with the insulation material, and pushed into place by two brackets.
    Bing (1)
