Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#586 dasupersprint
dasupersprint
  • 848 posts
Posted 22 April 2020 - 01:34 PM
That's a big step, knowing the value of the car ;)
It means it's (nearly) finished!!
And when one is doing small jobs like dash or companion bin upholstery, the end is not that far away!!
Mine is not very valuable at the time, but takes every day some more pennies haha.
PS: thumbs up for the small details like "arrière" or "droite" from a native french speaker ;)
Bien vu pour les mots français!
Knowing the value is more for the insurance than me, because I don't want to sell it even in the long term, and I know I won't ever see again the money that it cost me to repair.
Tomorrow is my technical inspection, I hope I come back with the sticker of approval!
#587 dasupersprint
dasupersprint
  • 848 posts
Posted 24 April 2020 - 04:41 PM
The Mini failed the technical inspection...
For three electrical things....
1. Right side high beam doesn't work. Probably my bad not to check, I really hope it's just the bulb that is out, my boys have been playing with the lights a lot.
2. Wipers too slow. It's true that they are slow,  didn't think it would be problem. The wiper motor and rack are the only thing that I didn't take apart on this car...I will soon and try to clean everything, and maybe wait for a order of parts if necessary.
3. Dash lights not bright enough. That one puzzles me. We all know the dash lights wouldn't be really bright on a cheap 70's car...and they work as original... It was sunny outside and we couldn't see them. I think this one was just to mess with me. I don't know what to do else than put LED lights in place? Bypass the rheostat that control the current?
#588 Quinlan minor
Quinlan minor
  • 1,377 posts
Posted 24 April 2020 - 07:22 PM
LEDs are probably your best chance. Testers are used to them and forget what incandescents looked like back in the day.
I have a similar squabble, most years, because the rear brake test doesn't reach the same indicated level they're used to seeing from two and a half tonne, disc-equipped 4x4s. " The handbrake's OK, though." Sheesh!
#589 Syma
Syma
  • 73 posts
Posted 28 April 2020 - 02:53 AM
This is what I put in my car to increase the dash lights. It comes as a set but DO NOT USE the bulbs for the turn signal, ignition, and high beams. They will burn out. Fortunately those ones are bright enough that I just used the 4 bulbs, two for centre gauge, one for temp and one for oil pressure
https://www.ebay.ca/...872.m2749.l2649
#590 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 28 April 2020 - 04:23 PM
On the wipers, I find that it's usually the little gearboxes that have gotten stiff over time - the grease gets old and hard - before you take everything apart, take the wiper arms off and  try to spray some penetrant into the shafts - it's a little hard to do but give them a good squirt and then run the wipers a bit and see if they don't improve. Maybe that will at least get you thru the inspection as I doubt you'll be driving much in the rain? Then you can always pull the assembly out at a later time and fix them if needed.
Edited by Magneto, 28 April 2020 - 04:23 PM.
#591 dasupersprint
dasupersprint
  • 848 posts
Posted 28 April 2020 - 06:25 PM
I already took everything apart and put new grease. But then I blew the fuse when trying them. Will retry tonight, and I will add a ground wire from the motor to the body too.
#592 timmy850
timmy850
  • 3,603 posts
  • Local Club: MITG
Posted 29 April 2020 - 04:56 AM
I’d also add some rainex or similar to the windscreen, it makes it a bit more slippery for the wipers.
On a dry windscreen they’re pretty poor from all the friction
#593 dasupersprint
dasupersprint
  • 848 posts
Posted 30 April 2020 - 05:11 PM
I took care of the wipers. I found that the main cause could be the inner brushes in the motor that were in bad shape. So I sourced a new motor from a friend, that saved me the wait for a overseas order.
Still, I cleaned everything, put new grease in the rack, lubricated the wheel boxes, put RainX on the windsreen. I also had two sets of wiper blades, one Bosh and one Wipac. The Bosh has a lot more friction going against a dry windscreen. Guess witch one was on the car at inspection...
Now they are faster than fast
Edited by dasupersprint, 30 April 2020 - 05:12 PM.
#594 dasupersprint
dasupersprint
  • 848 posts
Posted 30 April 2020 - 05:23 PM
I fixed the high beam problem too. The wires were inverted for high and low beam.
#595 Magneto
Magneto
  • 891 posts
Posted 30 April 2020 - 05:41 PM
I've found the wipers move just fine on a dry windshield when everything is clean and freshly lubed.
Good job on the high beams, it's easy to mix those up.
Edited by Magneto, 30 April 2020 - 05:41 PM.
#596 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 30 April 2020 - 05:42 PM
Nice!
These are at least two issues sorted!
Concerning the dash lights I agree with you, they are not what one can find nowadays...
Hope you will get that MOT tough!
#597 dasupersprint
dasupersprint
  • 848 posts
Posted 01 May 2020 - 05:22 PM
So I changed the bulbs behind the dash for LEDs.
Back on the worktable...
Those LEDs are so cheap they break if you look too hard at them
#598 dasupersprint
dasupersprint
  • 848 posts
Posted 01 May 2020 - 05:23 PM
Before/After. That will have to do, because I can't do anything else
#599 dasupersprint
dasupersprint
  • 848 posts
Posted 04 May 2020 - 05:07 PM
I received a tachometer so I installed it. It even works! That's a must have, I think. Plus, it's the smallest and cutest tach ever
#600 dasupersprint
dasupersprint
  • 848 posts
Posted 04 May 2020 - 05:08 PM
