Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#556 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 20 March 2020 - 01:45 PM
I had such an issue with my previous Mini I bought as a no-runner.
When I pulled off the fuel line which comes on the carbs there was a suction noise.
After changing the mechanical pump to a new one, same issue.
The problem was the fuel line going out of the tank, it was twisted so that the pump could not suck fuel...
#557 dasupersprint
dasupersprint
  • 848 posts
Posted 20 March 2020 - 02:32 PM
Thanks, I will double-check that too. And good thing to check the suction noise just to see if the pump is at least operating
#558 timmy850
timmy850
  • 3,605 posts
  • Local Club: MITG
Posted 20 March 2020 - 09:19 PM
I’d try filling the carb bowl with fuel, and if that doesn’t get it running long enough you can also back fill the fuel lines from the carb end
#559 dasupersprint
dasupersprint
  • 848 posts
Posted 26 March 2020 - 08:14 PM
I fiddled with things since the last update. The petrol found it's way by spinning the engine with the starter without the spark plugs. Then my ignition was very off, so I placed the distributor roughly by aligning the mark on the pulley. Then I turned the distributor slightly to find fire, and it started!
It's running rough because no adjustments at all, but that's a very good step!
I tried to move forward but the clutch wasn't engaging far enough, you can imagine the noise it made when I tried to go in first gear.I adjusted it and will try again today.
#560 dasupersprint
dasupersprint
  • 848 posts
Posted 27 March 2020 - 05:36 PM
First ride yesterday!! Well, first four rides! My street is a dead end, we didn't go further than that.
The alignement is awful, the timing is rough but the fun is all there! Wow what a charm to go through the gears. (I'm not used to engage reverse though!)
#561 DamoMini
DamoMini
  • 40 posts
Posted 28 March 2020 - 01:35 AM
Congrats!
Love this thread because mine is a ‘78 1000 from Canada and your pics are a great reference.
#562 Hpal
Hpal
  • 109 posts
Posted 28 March 2020 - 02:45 AM
Great work! I've been following with interest too. I'm in Australia and I've got a UK built mini 1000 from 1972 and its very similar to yours in most ways, more so than the Australian models, and it's been a great help at times. You've come a long long way from when you picked it up!
#563 dasupersprint
dasupersprint
  • 848 posts
Posted 30 March 2020 - 12:44 PM
Took it outside again Saturday to put the bonnet on, give it a wash and mess with the alignment a bit
#564 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 30 March 2020 - 01:02 PM
Looks lovely!!
Just a front grille to add and it will look like a finished car :)
#565 dasupersprint
dasupersprint
  • 848 posts
Posted 30 March 2020 - 01:40 PM
Looks lovely!!
I just couldn't believe it while washing it! I fell back in love with the paint job, as quite a lot of dust accumulated in the past months.
The grille will go after I make the adjustments on the timing, and the spot lamps will go back after the technical inspection. After that, it's finishing stuff like the dashboard, make a floor for the boot and fun things like that.
#566 dasupersprint
dasupersprint
  • 848 posts
Posted 31 March 2020 - 04:56 PM
New battery! gift from my dad. The old one has a purchase sticker from 2001, it's time is done. It served me well to do all the testing though.
#567 dasupersprint
dasupersprint
  • 848 posts
Posted 02 April 2020 - 06:25 PM
Took the time to adjust the toe alignment of the front wheels yesterday evening with a self made tool. I ended up with about 1/16'' between rear and front. That will do until I do a more professional alignment.
#568 dasupersprint
dasupersprint
  • 848 posts
Posted 06 April 2020 - 05:01 PM
#569 Junior Mini
Junior Mini
  • 313 posts
Posted 06 April 2020 - 05:08 PM
Very Nice  :thumbsup:
#570 DamoMini
DamoMini
  • 40 posts
Posted 06 April 2020 - 09:03 PM
Nice - she sits well on those 13s
