Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#541 dasupersprint
dasupersprint
  • 848 posts
Posted 12 March 2020 - 01:35 PM
What they're trying to tell you is that where you have blocked off the second port on top of the float chamber, what you've actually done is blocked the vent/overflow.  With this sealed off the float chamber won't fill properly and you'll have problems getting the car to run.
Ok now I see. So should I leave the hole free? If it's an overflow, will there be fuel spills?
#542 Alex_B
Alex_B
  • 4,573 posts
Posted 12 March 2020 - 01:49 PM
On UK cars it usually attaches to a pipe over the clutch housing and ends up dumping to the floor. Just keep it away from the exhaust!
#543 dasupersprint
dasupersprint
  • 848 posts
Posted 12 March 2020 - 01:55 PM
I'll see what I can do with the remaining fuel pipe I have to get it as close to the ground as I can then.
#544 dasupersprint
dasupersprint
  • 848 posts
Posted 13 March 2020 - 12:44 PM
I will have to buy more fuel pipe for the carb float vent. Last night the auto parts stores were closed so I ended up putting the front arches, finally.
I had to lift the suspension to clear the arches when turning the wheels. It sits too high to my taste, and I will have to lift the rear too to balance the look. I think later I will trim the inside of the arches at the front to get the car lower. It will do for now.
#545 dasupersprint
dasupersprint
  • 848 posts
Posted 13 March 2020 - 01:09 PM
I also put the cutest little tiny filter over the breather
#546 pete l
pete l
  • 1,374 posts
Posted 13 March 2020 - 01:27 PM
What kind of sportspack wheel arches did you buy ? the rubber ones or fibre glass ? they look good, too good to be the rubber ones.
Pete.
#547 dasupersprint
dasupersprint
  • 848 posts
Posted 13 March 2020 - 02:02 PM
Pete.
Hey Pete, they are the fiberglass ones. My guy doing the paint had to adjust them quite a bit because they were really rough on the edges touching the body. And I understand that he couldn't see how it would turn out at the ends because without an engine, the front was really high up.
I bought the rubber arches 8-9 years ago, but threw them away because I found that there was no way to make them look goog
#548 dasupersprint
dasupersprint
  • 848 posts
Posted 16 March 2020 - 01:44 PM
Okay I bought a longer fuel pipe and rerouted the vent to the ground
#549 dasupersprint
dasupersprint
  • 848 posts
Posted 16 March 2020 - 01:45 PM
Also drilled a hole in the boot to fix the spare wheel. Still need to put the tyre on the rim
#550 dasupersprint
dasupersprint
  • 848 posts
Posted 16 March 2020 - 01:46 PM
I tried to start the engine for the first time yesterday. The power didn't go to the starter motor. I need to do more tests to confirm that the solenoid in dead.
#551 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 16 March 2020 - 01:58 PM
Great progress mate. Hope you can get it started soon, that's the exciting part!
#552 dasupersprint
dasupersprint
  • 848 posts
Posted 19 March 2020 - 01:06 PM
I sourced a solenoid from a local Mini friend. This one clicks! I installed it last evening but then it was way too late to try the starter
Edited by dasupersprint, 19 March 2020 - 05:42 PM.
#553 dasupersprint
dasupersprint
  • 848 posts
Posted 20 March 2020 - 01:22 PM
Round 2 of trying to start the engine. The starter motor works, but the petrol isn't coming to the carb. The petrol filter is super dry, even after a good 2-3 minutes of cranking. I've been suggested to put more petrol in the tanks so that the level is higher.
#554 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 20 March 2020 - 01:38 PM
Electric or mechanical fuel pump?
Sounds like it’s not operating.
You could try carefully putting petrol into the carb to see if the engine fires.
#555 dasupersprint
dasupersprint
  • 848 posts
Posted 20 March 2020 - 01:45 PM
It's mechanical.
First thing I'll try is put more petrol and remove the spark plugs to make the pump go faster
